Tinkerman
Got the '60 TR3A running today! YEA!!!!!!!!!!!!
For some unknown reason the fuel seems to be bypassing the front carb. After the initial startup and run we stopped and checked things out and found that the front carb bowl was dry. Will address that tomorrow but your thoughts would be helpful. It ran much better with both carbs working, heh!
Going to run some Lucas fuel cleaner through it tomorrow. Probably should put a squirt or two directly into the carb bowls just to get rid of any bad fuel.
Cheers, Dick
Cheers, Dick
