TR2/3/3A Finding valve lash with cam specs?
karls59tr
Bronze
Is anyone familiar enough with camshaft terminology that could tell me the appropriate valve gap for this cam: 227 degrees @ .050".........280 degrees cam lift ........ 420" valve lift on 109 degree lobe c/l
Any help most appreciated Karl
I'm afraid the specs do not tell the valve lash. You will have to contact the manufacturer for the recommended valve lash. There is a very mild slope on cams that takes up the lash without shocking the valve train...called the ramp. The ramp is something the manufacturer chooses and is not related to the left or duration specs.
Karl:
John's advice is best. Your cam doesn't seem to be on this list: > Triumph Cams <
Valve lash values are all over the place on that list, so its hard to deduce anything from just the specs you have given. Only the cam grinder will know for sure. I note that none of those listed have as much (gross?) valve lift as you indicate.
Andy
Karl:
Andy
I'm going to get in touch with the cam grinder. I vaguely remember .016 but that seems a long way from the stock .010. The Tr3 seems to run OK at .010 except for an irregular idle. No other modifications except for exhaust header.
I have the Isky TR-555 grind and use 0.015 which was recommended with the documentation.
Seems to work well.
The sound of the engine is always a good check. At the proper lash, only we gear heads can hear the slight ticking from the valve train. If there is too much, then it starts to sound like a sewing machine that your wife thinks is "cute"...the point being everyone notices the excessive ticking. If too tight you hear nothing, and normally get a rough idle.
You must have the TR-555+10 Isky cam according to the chart. It seems the chart is using the .040 measurement rather than the .050 one? I"m finding it difficult to wrap my head around the whole issue.:unsure:
D Finding a Posting FORUM Navigation Questions 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
B TR4/4A Finding compression stroke Triumph 7
O Finding Gerard Spridgets 9
A TR2/3/3A Need Helping finding windshield bracket! Triumph 5
T Finding Datsun 210 transmissions or other obscure used components Spridgets 1
T Finding an accurate tyre pressure gauge? Spridgets 5
B TR4/4A Need Help Finding Triumph 3
T Finding help to actuallyl get projects completed Spridgets 4
2wrench TR6 Need help finding gear shift lever spring retainer, please -- HVDA install Latest. Triumph 9
M TR2/3/3A Finding top dead center Triumph 6
E Need help finding the builder to my 65 Spridgets 18
C Need Help Finding Torque Specs for Engine Austin Healey 1
S TR6 Finding a 69 tr6 Triumph 2
jhorton3 Finding Midgie A New Home Spridgets 0
krswen General TR Need help finding remote brake reservoir .... Triumph 2
krswen Need help finding brake reservoir Austin Healey 5
justin_mercier Post-War Other Need help finding a triumph 2000/2500/2.5pi autobox transmission Triumph 10
R Finding old posts Austin Healey 5
S I need help finding a correct bolt. Austin Healey 8
A Finding the fun stuff! Triumph 4
7 finding a coolant leak Other Cars 8
F Need help finding a part- door window track piece Austin Healey 5
richberman Help in finding part: Longbridge hot air outlet Austin Healey 3
T finding a coolant leak Austin Healey 3
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
T Finding engine ID Austin Healey 7
N Help finding a part Triumph 7
T help finding stromberg parts Triumph 5
T longer wheel studs need help finding Triumph 11
A TR6 Finding TR6 Project? Triumph 22
R Help finding part Jaguar 3
M Finding Tires for Midget??! Spridgets 8
Basil Help finding part Jaguar 11
wkilleffer MGB Finding 74 MGB starter stuff near Chattanooga, TN MG 4
M finding vendor Spridgets 1
M finding vendor Austin Healey 3
Cyberpyr8 Need help finding a solution Triumph 23
T Brainstorm me a disagnostic finding Triumph 14
GeeBee1 TR6 Finding a late model TR6 Triumph 9
TR3sharon Help finding grounding clips Triumph 6
G Finding TDC or Waiting For Godot Triumph 17
S Need Help Finding a Part Austin Healey 1
B Finding 50A Fuse for Horn Locally? Austin Healey 15
G Try finding THIS short..... Triumph 9
Bayless Finding TDC on a flathead motor Other British Cars 16
M Finding an old healey Austin Healey 5
bash Electrical fault finding Triumph 8
J Finding Exhaust Leak MG 4
floyd TR6 finding a tr6 repair manual Triumph 14
