Engine Misfiring & Starter Cranks Slowly When Hot
Frameman 1949
Hello all,
I’m have a problem with two issues. First is a misfire while driving that occurs at 4200 RPM. I have rebuilt the SU carbs and adjusted them to what I believe is correct, although I must admit to not being really sure of this. The engine has had the timing adjusted properly I hope.
The ignition points were replaced and the gap set to what my manual advised. The spark plugs are old but still working.
The engine was locked when I got the car and I got it freed up and running although the cylinder compression is a bit lotw as a result of the build up of carbon and powdery rust in the cylinders which is gradually improving.
My second problem is what I think is a heat soak issue with the starter motor. It works fine when first started but cranks very slowly when at running temps, 160 F. Allow to cool for 10 minutes and it will restart.
Any thoughts will be appreciated.
My first steps would be to replace condenser, points, and coil. In that order. Condensers do all kinds of inexplicable things for reasons you can't guess. The spring that closes the points can fatigue and not get the points closed at higher RPM. Coils, like condensers, do the inexplicable and tests do not necessarily duplicate operating conditions. Best test for a coil is replacement. They aren't that expensive. Carburetion is not likely to be your problem. There is a maxim sometimes repeated here that says 'When you are sure it is carburetion, rework the ignition again'.
Bob
Bob
Bob
Thanks Bob,
I had already changed the ignition points and condenser.
I just finished ordering the coil and plugs
On the starter when warm ... check the battery voltage Might be that the battery is losing charge from a faulty alternator/generator, so the starter gets lower voltage after a run, than when the car has been sitting. Just a thought anyway.
Tom M.
Good advice so far. My two ¢:
1) (misfire at high RPM) - Run the car in a dark--but well-ventilated--area and look for arcing around the distributor cap and, as suggested, the secondary wires. Aftermarket dist. caps are mostly crap; believe it or not OEM Lucas are best in my experience.
2) (sluggish starter) - This is a not uncommon problem. First, as suggested, make sure you have a robust battery. Unloaded voltage doesn't tell you much, test with a load tester or, better yet, a battery condition tester. Old-type starters--no fancy exotic metal permanent magnets for us!--get weak when the insulation on the field coils and armature breaks down with age and heat makes all things electric behave badly.
Battery tester (cheapest I found, may not be great quality): https://www.amazon.com/2Ah-220Ah-Re...ocphy=9032278&hvtargid=pla-1453557526312&th=1
If you decide a starter rebuild is necessary, most starter/generator shops can do it; nothing exotic about Lucas, or you can send to Star Electric: > Star Auto Electric - Home / British refurbished electrical components. <
My BT7 starter had the same issue. Like previously stated make sure your battery is good and you have good electrical connections.
I then replaced the Oilite bushings for the armature shaft and also replaced the small bendix spring.
That took care of it, spins the engine really good now.
Frank C. BJ8 Engine Misfiring Austin Healey 14
356roadster 100M engine: misfiring after ingition turned off Austin Healey 13
BoyRacer Wanted BJ8 engine block - Wanted Austin Healey Classifieds 5
cguild TR2/3/3A TR3 1991cc engine emits black soot from exhaust Triumph 13
mctriumph SOLD!! Re-built Tr4 engine Triumph Classifieds 0
B MGB Engine bay MG 3
G TR6 TR-6 Engine and transmission. Triumph 6
G For Sale TR-6 Engine For Sale Triumph Classifieds 2
Michael Oritt Engine Startup After Rebuild Video Austin Healey 19
S MGB Engine sputter upon acceleration MG 2
trbby2 TR4/4A Engine guestions Triumph 2
D A Red Engine In a Big Healey Austin Healey 19
S For Sale FREE - TR3 engine and transmission Triumph Classifieds 5
R TR2/3/3A Engine revs up and down Triumph 7
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
L General Tech Engine id Triumph 9
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 6
J Can a TF engine be installed in a TD body? MG 8
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
