This is great feedback.
John: My bracket was black. I was told it should be engine color. So I changed that. If you know for sure it should be black, then I change it back. Can you confirm? Yup, I cleaned that plastic and yellow it stayed. It looks ok, but maybe I should replace.
Rob: 1: The Johnbull strap is used. I notice two ways to hold the capillary tube. One is the strap goes though the circle as Norman shows and the other is the way I have it, with the circle free and the strap wrap around the heater hose and the capillary tube. Wonder if that is a deal breaker?
2: I spoke with David Nock about that. He said my relay does not have a sticker. My relay has the wires on the bottom and page 11 shows a relay with wires on the top. Different relay, different year, no sticker. Is David wrong?
3: yes, wire harness label is there.
4: I wondered about that short hose. I'll paint it, thanks.
5: I am missing the decal on the top of the voltage regulator. The Nocks don't supply them. Know where I can get one?
John. I removed the carbs and used a wire cleaning wheel via my hand drill. Then a polishing wheel and two different polishes. Still see some of the pit marks that the aluminum has. I didn't want a complete smooth chrome finish. Now when I clean, or polish them, they don't look like that grey/aluminum dull finish I used to get. Sort of a dull shine. Does that make any sense at all, duh.
Keoke: Not sure what your asking. I take an another photo, attached here, of that area for you. The heat shield is painted green. Next post will show a photo of my horns. I think the PO replaced with Moss. They work, sound good, fresh paint, I can live with them even though they are not orginal. But please do explain how my wires should be run.
Gonzo: I ordered the drivers side from Brad. Thanks for asking. The drivers side was aftermarket and passenger was original it turns out. That explained the fit issue.
Rob: I love painting. I repainted that bracket black for the paint was old looking. Now I get to repaint it blue to match the car. And I get to paint the screws too. Does anyone here do anything correct the first time, or is it just me. I am getting very good with a spray can.
Nevets: My year does not have the blue/white Girling label. Just the white letters saying: brake, clutch. Mine are located on the very bottom edge of the canister. Respective to the brake and clutch tubes.
Thanks everyone for your input and compliments. We all know how much time is spent on the little stuff. Roger...that.
