    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
GT6 GT6 engine compartment valences
roger_abbott
I recently acquired a 1972 GT6. It is my first Triumph and my question is about the radiator and engine compartment shrouds (referred to as valences by VB). They are made of cardboard. After 30 some years, the cardboard is in pretty bad shape. I am considering replacing it with aluminum. If anyone has done this replacement, I would appreciate your observations on the results, such as noise, vibration, etc.
Hi Roger,
I have installed aluminum in my GT6+1970. I took the old shrouds to a tinsmith and he cut and broke new ones with safety edges and a double lip on top to replace the metal on the cardboard ones. I had to do some trimming to fit around the firewall, and the altenater is close to top edge on the drivers side. No noises or rattles, and it looks much better then the old cardboard.
Joe
If your old ones are good enough to make a template from, you may want to think about masonite (hardboard) instead of aluminum. I have seen them cut from hardboard, then painted with an epoxy paint for waterproofing (particularly the edges), and mounted. Its easy to work with, you don't need a 'frame' for it (like the cardboard) because its stiff enough, or a rolled edge (like the aluminum) for safety. Its easy to 'trim' a bit if you need to fiddle-fit, and you can drill mounting holes in it directly, so no brackets.
I have heard of folks also coating the masonite with fibreglass for waterproofing, added strength, and a better textured look, then spray painting to match whatever colour you need.
If they're bolted in securely, there should be no rattle with either aluminum or hardboard.
i'm going to go with aluminum personally, but i'll still have to get some valences still since mine didn't come with any.
on a side note, i just came into a 1972 gt6 too, so keep in touch. gt6 owners are few and far between, and mostly ones with similar models it seems. /ubbthreads/images/graemlins/savewave.gif
Thanks very much for your help. I think I will go with aluminum because there is a bend that I don't think I can make work with hardboard (masonite). If they turn out, I will post some pictures of the results.
Roger, the bend is easily duplicated using Masonite. You just need to bend two pieces of aluminum or steel at the appropriate angle, leaving about a 1" flat on each leg. Then rivet the two sections of masonite together using these pieces at the joint.
Having said this, I've got brand new cardboard ones for mine, but will probably be making some from aluminum in the future. Hmmmmm... I've got some Titanium sheet stock left, maybe that would be better! /ubbthreads/images/graemlins/jester.gif
Jeff
6TTR3A Wanted GT6 MK one engine fan Triumph Classifieds 0
brgrmyster GT6 GT6 Engine Mount "Spacers" - What's the Purpose? Triumph 2
Darwin GT6 GT6 Engine specs Triumph 4
dklawson GT6 Mk1 GT6 Engine Rebuild Triumph 36
jollyroger Spitfire GT6 engine in 76 Spitfire, source for trans cover Triumph 6
P GT6 Gt6 Mk1 engine parts Triumph 0
IanF GT6 GT6 engine vs. TR250/6 engine? Triumph 12
F GT6 GT6/TR6 Engine Painting Procedure... Triumph 3
F GT6 TR6 dual exhaust manifold on GT6 engine? Triumph 2
2wrench GT6 1973 Triumph GT6 MK3 Engine for a TR6, yes or no? Triumph 10
F GT6 GT6 Engine Identification Help Needed... Triumph 10
F GT6 GT6 engine questions... Triumph 6
F GT6 GT6 Engine Rebuild Questions... Triumph 5
S GT6 GT6 engine in a TR6 Triumph 3
svtmikey GT6 TR6 engine parts in a GT6 Triumph 9
T GT6 GT6 engine question Triumph 7
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
ccw283 GT6 GT6 fender flares Triumph 1
B GT6 trying to ID my New Car. GT6 Triumph 6
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
Writer2022 GT6 GT6 Stiff Gear Selection Triumph 4
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
D GT6 9 months later. GT6+ progress Triumph 3
luke44 For Sale ‘72 GT6 MKIII For Sale Triumph Classifieds 0
LarryK GT6 Fresh purchased GT6 Triumph 11
O For Sale 1969 GT6+ Mostly rust free. Triumph Classifieds 3
idlehands Wanted WTB GT6+ driver (LHD) window glass and a single rostyle wheel cover Triumph Classifieds 1
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
idlehands Wanted GT6+ Triumph Classifieds 11
E GT6 Triumph GT6 MKIII rear hatch springs Triumph 2
B Wanted wing windows gt6 Austin Healey Classifieds 0
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
UltimateQuestion GT6 GT6 Mk3 rear wing removal Triumph 3
S For Sale Triumph GT6 Workshop Manual on CD/ROM – 1966 through 1973 Models Triumph Classifieds 0
Tybalt Spitfire Spitfire vs GT6 Front Hub Question Triumph 0
H GT6 GT6+ seat panels Triumph 2
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
R GT6 Looking to purchase GT6 Rust repair question? Triumph 4
R GT6 Triumph GT6, basic work estimates Triumph 76
glemon GT6 GT6 Getting Some Recognition Triumph 8
R For Sale Triumph GT6 3.27 rear Triumph Classifieds 2
brgrmyster GT6 67-68 GT6 Mk1 exposed pushrod tube color? Triumph 5
brgrmyster GT6 1968 GT6 MK. 1 original emissions lines Triumph 0
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
Spritey For Sale .. or [TRADE] Early GT6 seats Triumph Classifieds 1
