Seam sealer in the Engine compartment?
cyaker
I have been using seam sealer all along, but now I am to the engine bay and do not remember finding seam sealer in the strip phase. I am not going for a 100-point car. Have mixed feelings, like the extra protection of the sealer, but would like a clean crisp look in the engine compartment. What is correct? Then what are you doing?
I will be going with body color in the engine area.
My '71 TR6 did not have seam sealer in the engine bay. Only in the passenger compartment, trunk and wheel wells.
PatGalvin Seam Sealer for Engine Compartment Triumph 21
B TR2/3/3A seam sealer front fender and cage muts, undercoat Triumph 7
drooartz Seam sealer for fender beading? Spridgets 9
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
P What's the best seam sealer to use for panels on bare shell? Restoration & Tools 7
J Seam Sealer, do I need it? Spridgets 1
JohnnyMead Seam Sealer on the Fire Wall Triumph 4
R TR6 TR6 Interior Seam Sealer Issue, Restorers! Step In Triumph 4
1 Removing seam sealer? Austin Healey 6
C Best way to remove seam sealer? Triumph 5
fabmandan Seam sealer question Spridgets 8
C Under body seam sealer? Triumph 2
Lin Seam sealer - original application Austin Healey 2
fmichaels seam sealer Spridgets 9
71tr body panel seam sealer Triumph 1
Boink Fender seam annoyance... Spridgets 4
Rob Glasgow Seam Caulking Austin Healey 4
R removing black seam sealing Austin Healey 3
M_Pied_Lourd Body Seam Triumph 8
M Seam seal or not??? Triumph 7
T TR2/3/3A TR3A rear valance lower seam Triumph 2
M TR2/3/3A TR3 body question seam or no seam Triumph 7
T Question on seam welding - why not do it? Triumph 18
jjbunn Chrome seam covers Triumph 3
6 Seam Sealant: Remove, Replace, Leave Intact? Spridgets 1
B TR6 Gasket sealer Triumph 1
K TR2/3/3A Manifold gaskets....To use sealer or not? New ones look like fiber,old ones look like metal??? Triumph 3
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
S TR2/3/3A temp gauge sealer Triumph 7
D TR2/3/3A Sealer plate Triumph 4
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
S TR2/3/3A steering box sealer Triumph 9
T TR4/4A Head gasket sealer question Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
S TR2/3/3A gasket sealer for the bear plate Triumph 7
Patrick67BJ8 Sealer between fenders and shrouds Austin Healey 12
PatGalvin Front Wing Sealer Plates Triumph 5
M Tank Sealer in Alu. Fuel Tanks Austin Healey 4
KVH Fuel Tank Sealer Triumph 3
DNK Fittings Sealer Triumph 6
B Gas tank sealer...whats your opinion? Triumph 29
TulsaFred Fender beads look kinda lousy, sealer? Spridgets 9
M Water Pump Gasket & Sealer Spridgets 10
Superwrench Rear shroud sealer Austin Healey 3
sail Gearbox Sealer Triumph 2
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
