Engine build...thanks Superwrench!!!
richberman
Final pictures loading up my tricarb/toyota 5 speed from Superwrench's garage after a marathon 12 hour day!!!
Yipee!!!!
:savewave: Sure looks fine. Who's paint did you use? What quantity? How did you treat exhaust manifold? Did you use a primer? As to the new exhaust, I was disappointed to see that the long stainless exit tubes after the muffler are approximately 1/4" smaller in diameter than my stock pipes. Thanx for your splendid photo gallery, I know it will come in handy as I put my tri-carb back together this spring. :cheers:
Hi "Superwrench"
When I look at the second picture I see the engine looks great but in my imagination I see as well between the tree and the manifold the MG of your friend.
Harry
Harry, We did enjoy your visit. Hope you can get to the states again soon ! Elrey, I use Rust-oleum 2000 degree primer on manifolds, but told Rich that the green will still burn off. :cheers:
Lin,
I can't wait to get it into the chassis. I saw your pictures and decided to put it in "BEFORE" installing any of the body panels or shrouds! I didn't think I could handle the stress of watching it hang over a freshly painted shroud.
Rich
Hi superwrench. I know this may be a dumb question to all of you that know each other, however, did you do the engine build for him? I am asking because I see you are in York, PA and I am in Pylesville, MD (just south of the PA/MD line near Bel Air, York is about 45 minutes for me) and I am restoring a 59 BN4. I am finishing the final body work and will paint the scuttle when the weather warms. Anyhow, i am looking for a qualified engine builder since the AH is a little out of my knowledge. Most of my work (hobbyist) is on camaro's and mustangs. I posted some pics about a year ago of the stripped down shell after the chassis metal work was completed and it was being soda blasted. If you are interested or can give me a recommendation, it will be greatly appreciated.
BTW, this is a very helpful site and this engine looks great!
Regards,
Doug
Can't help with an engine builder in your area, but if you can rebuild a Camaro or Mustang engine you can rebuild a Healey engine. They are butt simple--not unlike a Chevy stovebolt--and any decent machine/engine shop should be able to handle any block or head work you might need. If you had any specific questions or concerns on the rebuild you could post here and likely get plenty of useful tips and information.
Thanks Bob! Maybe I will give it the ole college try. There is a local machinist that did the work on my 69 SS396 camaro engine and it worked out great. I think I may give him a call.
Cheers
Doug
There's a shop in my folks' hometown of Modesto, CA that is a well-known racing smallblock builder. He's done machine work for both my BJ8 and our BN2--heads, mostly--and all work was top-notch. He has a New Zealander working for him my dad says is an absolute perfectionist.
Things to consider:
<ul style="list-style-type: disc">[*]whether to use iron or bronze valve guides (or both) [*]getting quality rod and main bearings [*]lightening the flywheel while you're at it?[*]install rear main seal? [*]send rocker arm out? (I would)[*]install spin-on oil filter adapter?[*]minor porting of head (arguably one of the best ways to get a little more HP)? [/list]
The list goes on ...
Doug, I sent you a PM. I will help in any amount. There are a lot of good shops in our area. There is a ton of Knowledge here also to help you, Bob's list is a starter, Randy, Red 57, Rodger and the rest will chime in I'm sure. Good luck
Michael Oritt Engine Startup After Rebuild Video Austin Healey 19
KVH General Tech More Engine Rebuild Questions Triumph 15
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
J Engine rebuild Austin Healey 4
classicmechanic Amazon engine rebuild pics Other Cars 6
H MGB Engine build question MG 10
M 948 Engine Rebuild Question Spridgets 0
M engine stutter of rebuild BT7 engine [tri-carb] above 2500 rpm Austin Healey 27
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
M E Type 4.2 engine rebuild Jaguar 4
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
Healey Nut Engine rebuild Austin Healey 17
Got_All_4 TR6 What engine bearings to use in my rebuild? Triumph 9
R BT7 engine gallery plug replacement during rebuild Austin Healey 3
RAC68 What's with all the Engine Rebuild Failures? Austin Healey 42
T Selecting octane levell for new engine build[?] Spridgets 7
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
G Failure on Initial Engine Start After Rebuild Austin Healey 176
HighAltitudeTR3 TR2/3/3A Any feedback on this? Rimmer Bros engine rebuild Triumph 6
KVH General Tech Engine Rebuild: Failed at Cam Break-in Triumph 11
simon1966 A few shots from the 100 engine rebuild Austin Healey 18
JimLaney Engine rebuild - how critical is rust? Spridgets 3
G TR4/4A A couple of engine rebuild questions... Triumph 8
N Engine rebuild ??? Spridgets 4
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
Csarneson Engine Rebuild Disaster - Cylinder Crack Austin Healey 20
D Engine rebuild questions. Austin Healey 18
M Need Advice On 948 Engine Rebuild Spridgets 7
W TR2/3/3A Novice TR3 Engine Rebuild Triumph 47
J TR2/3/3A TR3 engine build Triumph 12
KVH TR4/4A Generator Light Turned on While Out on New Engine Build Drive Triumph 9
W TR2/3/3A Engine rebuild - looking for preliminary advice Triumph 7
T TR4/4A What is trickiest part of engine rebuild? Triumph 15
D MGB 1963 MGB engine rebuild MG 4
H Off Topic Nifty Time-Lapse Video of Spitfire Engine Rebuild Triumph 2
G TR4/4A Yet another engine build thread. Parts list: Suggestions/Recommendations/Etc Triumph 11
gbtr6 TR6 Engine Rebuild kit Triumph 12
gbtr6 TR6 TR 6 Engine rebuild/freshen Triumph 21
Rut TR4/4A Performance engine rebuild Triumph 3
me61ic Timelapse '63 BJ7 engine rebuild Austin Healey 5
Rut MGB Engine rebuild, then... MG 29
tomshobby Engine build invoice. Spridgets 4
mcmillal TR4/4A Engine / Transmission Rebuild Triumph 1
JPSmit Engine Rebuild question Restoration & Tools 10
S TR2/3/3A Engine rebuild Triumph 9
TexasSprite Engine Rebuild Video Spridgets 1
Healey Nut Engine rebuild Austin Healey 9
drooartz MGB Drew's going to build an engine this winter MG 13
mt10flyer TR2/3/3A 1959 TR3 engine rebuild problems Triumph 14
