TR4/4A A couple of engine rebuild questions...
ghawk16
So I'm getting ready to put my engine back together and am a bit nervous even though I've built Audi/VW engines so I can do it, but had a couple of quick questions...
1. The machine shop did a dry fit of the gaskets and sleeves and pulled everything back out. Well he threw the copper Figure 8 gaskets in a box and not back in the cardboard supported "box" the other gaskets came in. Well the gaskets are a little wavy but definitely not crimped in any way. I'm thinking they will be fine once the liners are in and flatten them out. I should be fine as long as they aren't folded or crimped in any way, correct? I'm planning to use Aviation gasket seal on them and the liners and block. Looking for more reassurance here that they will be fine.
2. Has anyone used the BPNW head gasket for larger liners and had issues? Guess I'm just looking for some reassurance. Should I put that on dry? I've seen posts where someone put copper around the sleeve openings. Use copper seal? Aviation?
3. Putting the BPNW 87mm set along with stock balanced rods...I didn't see a mark on the pistons that show which way they should face. I had the machine shop put the pistons on the rods and looking at the pictures the rods can only go in one way and I want to make sure the pistons are facing the right way. Anyone used a BPNW piston set with any helpful hints.
Thanks!
bobhustead
New figure eights are cheap. Especially compared to the time and money to tear down and reassemble if there is some problem. Replace them. Dunno anything about bpnw pistons.
Bob
mrv8q
TRF sells the copper Fo8 gaskets individually, if needed...
Dash
I gave the machine shop every spec I could get my hands on and had him do a complete internal rebuild using all bpnw parts. I can't report on how well it runs yet as I'm still installing the external gadgets and it's a body off restoraton so it will be a while me thinks. However, I can tell ya he installed the copper head gasket dry which he said he does with all his rebuilds. As long as you have the proper liner extrusion it should be fine. Concerning the 8's, if they are just bowed a little I wouldn't be too concerned but on the other hand if they have ridges, I personally wouldn't chance it. The stock pistons are assembled to the rod so that the slot faces the offset (cap) side of the rod. I don't remember if the 87mm's I got from bpnw had a slot but if they do, I would think it would be the same. I could ask my guy what he did if that helps but it'll be a couple days before I can do that.
Dave
G
ghawk16
Went ahead and ordered some new copper Figure 8's from BPNW where I got the piston/liner kit. Also ordered some Joe Gibbs lube since I won't be starting the engine a while after putting it all together so not sure the oil would stick around that long. Forgot to ask about the orientation of the pistons. Thanks for all the help guys.
malbaby
What ever head gasket supplier you use, do not assume that it will be a correct fit.
Check carefully for proper fit around the cylinder edges before installing.
I bought 3 from different suppliers before I found one that was the ideal fit.
G
ghawk16
Thanks
I bought all the engine parts, gaskets, seals, etc from BPNW so if something doesn't fit or work correctly they will be getting a call. Going to call them anyway on the pistons to make sure there isn't a certain orientation as I don't see any marks
D Lilly Engine Latest / couple of questions Austin Healey 34
M Help me ID a couple of bolts on my 1275 engine... Spridgets 5
AngliaGT Lotuses,Loti,er a Couple of Lotus? Spotted 4
AngliaGT At a couple of Car Shows in SW Virginia Spotted 3
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
DrEntropy A couple Cumberland SCCA Runoff shots, 1976 Racing 0
AngliaGT MGB-GT Couple of Dumb Questions - '67 GT MG 11
AngliaGT A Couple More Spotted 0
K TR2/3/3A Couple of choke questions Triumph 1
S TR2/3/3A TS27036 for a couple laps Triumph 13
D BT-7 couple of general questions Austin Healey 6
T TR2/3/3A Is there a timing cover seal that will last more than a couple of year? Triumph 23
matmire couple of Healeys in this Stella Cidre commercial Austin Healey 2
Steve A couple of bikes that my dad designed British Motorbikes 8
M TR4/4A Dash instruments.......couple of questions. Triumph 5
5 Couple of Spridgets for sale Spridgets 2
gbtr6 TR6 Couple of general resto questions Triumph 4
J TR2/3/3A A couple of questions. Triumph 13
PC last couple of days Spotted 2
BobMunch A couple Questions about later Midget heater cores Spridgets 0
J true value of a couple of books... Triumph 13
O TR2/3/3A TR3 Wheel Studs, Couple of Hinges Needed. Triumph 2
O TR6 Couple of Tr6 related questions Triumph 9
RickB Couple qyestions - plate light plinth Spridgets 3
T TR2/3/3A A couple TR3 body questions Triumph 4
AngliaGT A Couple of Tempting Deals MG 4
jackq MGC PLz save a couple of MGCs MG 6
T A couple of clutch questions Triumph 9
P A couple of TR# questions Triumph 26
theleisure A Couple [unwanted] Firsts... oil & temp Spridgets 6
T TR4/4A Lightening a TR4a flywheel - a couple of questions Triumph 7
S Couple pictures needed Austin Healey 5
livinginthepast Signing off for a couple months... Spridgets 7
VelodromeRacer A couple of vids from the KIC and Grattan Racing 1
GBRandy Wedge I was bored...a couple of TR8 pics Triumph 16
RickB A couple items I have For Sale Spridgets 0
Strapping_Lad I found my new baby! WTB a couple parts Spridgets 19
D New to MGs w/ a couple questions MG 16
RickB Anyone got a couple of these to share? Spridgets 2
S Alpine a couple steps closer to running Sunbeam (Rootes) 4
JPSmit couple of interesting cars on ebay Spridgets 5
John_Mc Couple of unique LBCs on CL Triumph 7
JPSmit Couple of things for sale Other British Cars 2
mrv8q Couple ZS 175 questions Triumph 9
Baz Couple more pics..... Spridgets 6
walshja couple of questions Spridgets 16
motofiaccone Project start and a couple questions Spridgets 15
Shealey Need a couple things... anyone? Spridgets 10
Adam58 A couple of English Fords needing adoptive homes Other British Cars 1
Tinkerman A Couple of Chrome Replating Questions. Triumph 5
