TR4
I installed new TR4 Tail Lights I recently purchased and the turn signals would not work. Not being electrically inclined, I took the old light to test the turn signal and it worked by touching the single wire to the positive pole on the battery and the housing to the negative pole. I tried that with the new light and it would not light so I attached a ground wire to the turn signal light socket and that would light it up. I thought I could use that ground wire to get the turn signal to work but no luck. Do you have an idea as to what I should try before I ask my mechanic to figure them out? Your advice would be greatly appreciated.
Rgds,
Phil
Rgds,
Phil
