JimTR4
Hi all,
I am in the process of fitting a new dash and a couple of replacement gauges (still...).
On removal of the dash I noticed 3 black wires (have tested them and they do indeed connect to ground/earth) all taped up with masking tape. Must have been done years ago because the tape kind of crumbled on removal.
Underneath the tape the 3 wires are connected to an eyelet. See pic with red test lead clip attached.
QUESTION: where is this supposed to be connected?
It hasn't got much spare play in it so it will have to be connected close by. I'd like to connect it where it should have been if possible but failing that any suitable grounding point I suppose.
Any suggestions?
Thanks.
Any suggestions?
Thanks.
