Electric choke-MG Midget 1978 Single Weber
jbuffalo
I removed the water choke because I was having hard starting in the heat-thought it would remove some of the heat. Also installed a thick gasket between the carb and the manifold-this seems to have fixed the problem. Had a electric choke for the Weber so I hooked it up with a wire(in line fuse) that was activated by the key on on. All seems to be working well-choke opens and closes as it should-some heat from the choke but not as much as the water choke. Anything else? thanks Jim
Sounds like you have it. You can adjust the dial to set the kick off point but if I recall, around 12 to 1 o'clock is pretty good. How thick is the spacer you installed? I don't have room between the air cleaner and the hood for any more height. In fact, the cleaner bumps the hood (bonnet) a bit when I shut it down as it is.
JC
Thanks-the electric choke seems to work well-is that the history? Spacer is about 3/8th of an inch. Cleared ok pierce manifold. Jim
Yup, I think the Pierce is supposed to be a little deeper than the Cannon... That said, there are (at least) two thicknesses of (DGV) chrome filter, so those with clearance problems can run the thinner one. I think it's 1 3/4" or so, from memory...
I'm running the 1 3/4" filter but on a cannon manifold. It clears normally but when the engine rocks on shutdown, it thumps the hood a bit. Might have to seek out a pierce manifold.
JC
O Electric choke problem. Jaguar 0
L Help with electric choke, 1960 AH BT7 Austin Healey 2
AndreL TR6 Conversion to electric fuel pump Triumph 14
Guido36 Electric Power Steering Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
DrEntropy Benz electric window battle Other Cars 13
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Spitfire Electric Fan Triumph 2
J Electric Ready? Electric Upgrades of All Sizes 3
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
Gliderman8 Electric classic cars Electric Upgrades of All Sizes 22
B Intermittent Loss of Electric Power Austin Healey 18
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
R Electric fuel pump wiring Spridgets 4
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
Rob Glasgow New Fangled Electric Overdrive Austin Healey 9
R Rewind electric motor Restoration & Tools 3
JPSmit Electric Midget Spridgets 1
M TR6 Electric Powered Rack & Pinion. Triumph 4
longbridgehealey Electric Fan vs. Texas Cooler Austin Healey 21
D Spitfire Electric fan Triumph 3
B TR4/4A Mechanical fuel pump vs electric Triumph 16
M TR6 Rimmer Bros. Electric Fan Conversion Triumph 0
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A An Electric TR3 ?? Triumph 3
Lin Electric Relay Placement Austin Healey 11
nevets interesting article about converting classic cars to electric power Austin Healey 7
FlyingCat Spitfire Electric Radiator Fan Triumph 10
M The electric E Jaguar 1
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N Electric fan opinions???? Spridgets 2
P electric clutch Austin Healey 1
M TR2/3/3A Electric Fuel Pump Sound Triumph 7
Geo Hahn General Tech Emergency Electric Fuel Pump Triumph 29
B Electric fan Austin Healey 2
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
rjc157 TR6 Electric fan Triumph 5
J Spitfire Electric brake switch issue Triumph 5
johnrip Wedge tr7 electric fuel pump Triumph 2
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
Got_All_4 General TR Electric fuel pump for in my possibles bag Triumph 12
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Electric Fuel Pump Installation Triumph 12
J TR2/3/3A Radiator removal ?? electric fan vs original Triumph 7
T ?Changing BE to SU electric fuel pump Spridgets 8
S TR4/4A electric fan Triumph 6
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
