TR2/3/3A EARLY TR3 hubs for wire wheel?????
vpanza
I am restoring an early 1956 TR3 TS 12010. The chassis has the four bolt Lockheed rear axle and while it had been converted to disk brakes on the front, I found all the parts I need to convert it back to Lockheed drum brakes on the front (yes, I know this is going backwards, but trying to maintain original configuration:smile:. My question is this: I see that the parts book specifies different hubs for steel vs spoked wheels. I compiled all the hub specs in the chart below:
Once again, this is from the original parts manual. As you can see, for the earlier cars, up to 13046, the hubs on both the left and right sides are the same for both front and rear (different parts for front and rear, but the same for both sides: same with those on the later cars after 13046).
What gets confusing are the hubs for spoked wheels. The books calls for different part numbers for RH and LH when installing wire wheels for both front and back.
I have a spoked wheel spindle and it fit on the hubs I currently have (car had steel wheels) and I am wondering what the difference is??? Could it just be the studs, which I can either change or cut????????? Of, is the design of the actual hub different from that used for steel wheels. And why a difference between RH vs LH.
I have a later axle and the correct disk parts from a parts car, TS 14666 and can install all of that, which I am assured is a better way to go. But as I noted, I was hoping to build the car to original specs.
TR3 Hub types
Position<13046>13046Wheel type
Front
109975​
114284​
Steel wheels
Front RH
108277​
114283​
Wire wheels
Front LH
108278​
114283​
Wire wheels
Rear
109553​
113175​
Steel wheels
Rear RH
109551​
113173​
Wire wheels
Rear LH
109550​
113173​
Wire wheels
Thanks in advance for any feedback on this question. As for the different studs, I am aware of the spacer solution, but would be more inclined to change the studs as I have the car apart at present.
Thx
Vic
CJD
Interesting. I can only guess...and that would be that the early hubs had left hand stud threads on the right side. Later they must have decided the reverse threads were not necessary. The steel vs wire difference is, of course, the length of the studs to clear the wheel spokes.
vpanza
vpanza
Thanks. If that's the case, I am home free. I'll check the threads on my early hubs, but as I recall, they all seem to be standard RH threads.
Really appreciate your comments
Vic
sp53
When you say hubs, are you talking about the knock offs? They should have a direction for rotation on the knock for left and right side so they do not come lose. It is counterintuitive when it comes to direction off turning, so as when the car rolls they stay tight. If done correct, and you pick the car up from the back to tow it, I guess the front knock offs can come lose at least that is what I heard.
Steve
vpanza
vpanza
No, I am referring the the hub that attaches to the axle and has the four studs in it for the wheels (or spinners). The spinners and knock-off's fit outside of the hub.
Thx
TR2 and early TR3 had this hub set up for wire wheels. Theres a special spacer used, which is near impossible to find. I have the whole set up I will sale. I kept it thinking I would find a TR2 to put them on. PM me if interested
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
R For Sale 1956 Early small mouth TR3 Triumph Classifieds 1
R TR2/3/3A Early TR3 electrical system Triumph 12
jfarris TR2/3/3A Uh Oh - will these carbs work on an early TR3 Triumph 4
jfarris TR2/3/3A Installing replica Brooklands Areoscreens on early TR3 Triumph 4
jfarris TR2/3/3A Early 56 TR3 H6 Carbs, distributor vacuum advance/retard Triumph 3
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
K TR2/3/3A TR2 early TR3 windscreen stanchions Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
M TR2/3/3A Which frame is correct for early TR3 Triumph 18
mrv8q TR4/4A TR3 vs early TR4 Triumph 11
M TR2/3/3A Who sells seal for early TR3 hardtop? Triumph 6
Marvin Gruber TR2/3/3A Early TR3 wire wheel set up. Triumph 9
T TR2/3/3A Early TR3/4 trans help needed Triumph 7
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
