    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Drain plug??
nomad
Does anyone offer magnetic drain plugs for the diff and trans?
Kurt.
Kurt,
I just stick a small re magnet on the end of the plug...works pretty good.
Rut
I can get them got the engine, but not seen them for the others. I think if you add a magnet, I would JB Weld it in place first. A rare earth magnet might be more secure.
Kurt.
Yeah, sticking a small magnet to the plug was considered. Think it would be good to collect the detritus and know how fast it's being produced.
Kurt.
I try to remember to stick a rare earth magnet on both the oil filter and on the drain plug on each of our fleet. Lee Valley Tools has a local shop here, but they also have a mail order facility. I don't know if the magnetst really make a difference, but figure that they are cheap insurance. They're usually still attached for the next oil change; biggest risk is forgetting to take them off the oil filter before disposal and then putting the dang thing down and not being able to find it again. Doug
Wonder if the bunch'es of refrigerator magnet's we seem to get would do any good stuck on the engine oil filter?
Kurt.
Hey, thanks, Bill!! Looks like I might be able to use a screw to attach one of those to the plug!
Might check and see if Triumph fits.
Bill's suggested magnets are great. I think I will order a bunch that can be screwed to the plugs. Trust that the most though I imagine just sticking them to the plugs would be good enough.
Kurt.
I have made magnetic plugs. I take a cylindrical rare earth magnet, measure its diameter, and drill a hole in the plug slightly larger than the magnet. Then I degrease the magnet and the hole and JB Weld the magnet in the hole.
Why do people put magnets on oil filters? Any metal chips that are caught by the filter magnets have already passed through the oil pump and are typically large enough that they would be caught by the paper filter element anyway. Is the goal to catch microscopic particles that are tiny enough to pass through the paper element?
I've dealt with these magnets. I can tell you that if you were to get one of the flat discs that is about the same diameter as the drain plug and either 1/8" or 1/4 inch thick, you'll be hard pressed to simply pull if off. They can be slid off easier, but they aren't going anywhere. If, and that is a BIG IF they came off the drain plug they would stick to the bottom of the oil pan and never leave. If you screw it to the plug, the screw could come loose with the vibration. Then what? Well that screw isn't going anywhere either, but I'd use red locktite anyway.
Good point, Bill, a screw is probably overkill and extra work.
Kurt.
Why do people put magnets on oil filters? Any metal chips that are caught by the filter magnets have already passed through the oil pump and are typically large enough that they would be caught by the paper filter element anyway. Is the goal to catch microscopic particles that are tiny enough to pass through the paper element?[/QUOTE]
Well, I guess (in my case), a combination of wishful thinking, and "why not?": cheap and can't hurt. Plus - since birds migrate based on magnetic fields according to some theories, maybe it'll help me get home? Doug
I doubt very much that even a strong magnet, placed on the outside of a filter, will create much of a magnetic field inside the can, anyway. As an experiment, you might try putting one on the outside of a tin can and then touch the inside with a screwdriver to see if there is any field there. Bet you'll hardly feel anythng.
And, yes, as I started to read this thread, I also wondered why anyone would do this, even if it does work.
Oh, and thanks for the link to that "Amazing Magnets" site. It may help with other things I'm doing.
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
D Socket for TR3 Gear box drain plug Restoration & Tools 6
B TR4/4A Oil Drain plug size Triumph 14
M TR2/3/3A TR3 Overdrive filter drain plug Triumph 7
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
drooartz Leaking 5-speed drain plug Spridgets 26
J TR2/3/3A Oil drain plug stuck Triumph 10
af3683 TR2/3/3A TR3B Oil Drain Plug Triumph 10
Lin Rear differential drain plug leak Austin Healey 16
wkilleffer MGB Classic Gold fuel tank drain plug MG 12
TulsaFred aluminum BE radiators on ebay, drain plug thread? Spridgets 12
warwick-steve Magnetic Gearbox Drain Plug Austin Healey 28
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
C BN1 Overdrive drain plug question Austin Healey 0
Marla TR4/4A Oil Drain Plug Triumph 4
catfood BN1 Rear Axle drain plug. Austin Healey 7
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
bighealeysource Fibre washer on O/D drain plug doesn't fit well Austin Healey 7
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 8
K TR2/3/3A Gearbox drain plug threads stripped? Triumph 1
K TR2/3/3A Leaking Gearbox drain plug....... Triumph 6
Scotsman Square Drain Plug Socket Restoration & Tools 7
KVH Leak at Oil Drain Plug Triumph 12
pipercollins 1500 Drain Plug with Remote Dipstick Triumph 7
tri_carb_healey drain plug bolt size 3000 bt7 Austin Healey 6
W Transmission drain plug Spridgets 8
M Overdrive drain plug Triumph 17
ScottTR6 Diff Drain Plug Spridgets 10
M Radiator drain plug question Triumph 5
W Transmission Drain Plug Triumph 5
drooartz Question: diff drain plug Spridgets 5
CinneaghTR Thread Pitch for TRactor Oil Drain Plug Triumph 8
TonyPanchot TR5/TR250 250 Diff drain plug ? Triumph 15
Tinkerman Drain Plug Set, Paint ?????? Triumph 4
L What size and thread pitch oil drain plug? Spridgets 5
KVH TR4/4A TR4 Water Drain Plug in Block Triumph 4
V Diff drain plug sealant? Spridgets 5
sparkydave 1500 coolant drain plug gasket Spridgets 0
BugEyeBear GT6 GT6 Coolant Block Drain Plug Location? Triumph 4
H TR2/3/3A TR3A Oil sump drain plug [Thread zize] Triumph 2
H Block coolant drain plug Spridgets 2
Stewart Leaky transmission oil drain plug MG 3
B Midgie 1500 drain plug size Spridgets 6
RickB YUCK!! Is there a floor drain plug 78 Midget? Spridgets 5
Darrell_Walker Engine block drain valve - replace with plug? Triumph 10
RandallRK Differential oil drain plug Austin Healey 13
C Water drain plug size? Triumph 0
R New floor boards, drain plug. Spridgets 5
Dave Richards Overdrive Drain Plug Gasket? Austin Healey 2
