Factory spec here is about .005 to .007 as I recall. Using the crude "feeler gauge in the pedestal space" test (with a washer under the gear), I'm getting .014. The Manual says to use a packing gasket if there is insufficient end float. What does a person do if the end float is too great, or is that OK?
