Distributor drive housing
Hairyone
I'm in the motherland & trying to source one of these: 12A1136
it supports the distributor drive shaft & the dizzy sits in it.
A bit on here missing
The engine I'm building for my frogeye, this was missing.
It's obsolete & I can't find one, so I'll have a look in the scrap yards at the weekend. Does anyone know what other cars with the A-series might have one of these? Is it also an A+ engine part?
It will not be the same as the A+ engines.
I would look for parts from a Morris Minor, A35, early Minis, Kestrels, Elfs, Hornets, and similar. Most early A-series should have that part. It should not be hard to get that part from someone with a collection of old BMC engines.
I've seen them on ebay from time to time...
Rut
I've seen them laying around in my spares collection. Unfortunately, it would take me a day to find them again ... assuming I didn't get distracted by something else I found. :wink:
Yes Ray, that's it. But the 2nd one you found is only available to USA, 1st. ones ended, I guess I'll have to keep looking. I'm doing a scrap yard search tomorrow, I forgot about the Elf, thought not many of those around.
So it's in everything from the earliest small bore A, but not A+
Thanks
Hairy.........
I have some. E-mail me at oneandout (at) att (dot) net
and I'll give U details.
JB
If all else comes to naught, think I have one or two in my stuff. Let me know, they not going anywhere.
Yes, I think they were in all A-series (without change) until they introduced the A+ which has a different distributor mount. You should have no trouble finding one in the scrapyard or a U.K. shop that works on older cars.
This is not engine size dependant either. Be sure to look for donor engines from the 850cc on up.
Thanks JB & Jack, I'll keep looking here in UK for a bit, but no joy in 3 scrap yards so far. Scrap yards here in UK have changed over the last few years, with health & safty law & the high price of scrap metal there are fewer much cars to climb over. May contact you if I don't find anything in a week of two. Thanks
Adrian
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
Csarneson Source for distributor drive peg? Mystery Part? Austin Healey 8
L TR2/3/3A Noise seemingly from Distributor drive gear Triumph 15
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
S TR2/3/3A Distributor drive shaft play Triumph 4
S TR2/3/3A distributor drive shaft gear Triumph 4
eschneider TR2/3/3A TR3 distributor tach drive disassembly Triumph 7
PatGalvin Distributor Pedestal Tach Drive Triumph 2
M Distributor Drive Gear MG 10
M Distributor tach drive seal replacement ???? Triumph 2
Dadandson Setting the Distributor Drive Gear.... Spridgets 5
KVH Distributor Drive End Float Triumph 6
M Distributor Drive Dog Removal Triumph 8
B B series distributor drive gear. MG 1
F BJ8 Distributor Drive Position Austin Healey 5
T TR6 TR6 distributor removal - tips on tach drive Cable Triumph 5
wkilleffer MGB 1974 MGB distributor drive dog- which one is it? MG 8
TulsaFred Fixing distributor that is "one tooth off" Spridgets 3
T TR6 TR6 distributor issue Triumph 6
zoohow Distributor Bolt Lock Washers Austin Healey 1
B TR4/4A Some Help with Setting Distributor Triumph 47
C MGB New plug wires and distributor cap MG 10
M Accuspark distributor Spridgets 2
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
K TR2/3/3A Dr Distributor shipping? Triumph 4
E TR6 Rebuilding Distributor Triumph 2
K TR2/3/3A Distributor internal wires? Triumph 5
PAUL161 T-Series My 55 TF Xpeg Distributor MG 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
JPSmit Distributor question Spridgets 0
B MGB 42d4/45d4 distributor MG 0
S TR2/3/3A Installing the distributor pedestal. Triumph 3
A TR6 TR6 Distributor cap issue Triumph 4
C MGA Setting a 123 distributor MG 0
K TR2/3/3A A couple of small distributor tech questions..... Triumph 10
vette Distributor Advance Austin Healey 14
AngliaGT MGB-GT Extremely Dumb Question - Distributor Hose - SOLVED! MG 3
1275GT Wanted 23D4 distributor #40819 Other British Classifieds 0
M TR2/3/3A 25D4 CSI Optimized Distributor Triumph 4
T TR4/4A Why are distributor base plates different, is this a problem? Triumph 7
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
steveg 100-4 Distributor Internal Ground Wire Austin Healey 6
WJKB-TR6 TR6 '73 Distributor Cap Brush Triumph 5
R Distributor: Reassembling BJ8 Engine Austin Healey 5
Lin Jaguar Distributor Cap for Healey Austin Healey 8
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
Lin Distributor to Spark Plug lead wire continuity Austin Healey 5
