Churchill tool I.D.
PhilW
I got a tool with a box of old Jag parts and I was wondering if someone could ID it by the number (JD6D/4).
It looks like something to make a flange in an exhaust pipe. It would be nice to know if it's something important, before I grind it and start using it in my press for common pressing.
Phil.
Got a picture of it?
P
PhilW
Here's a photo of the tool. A rod from a press goes into the mushroom shaped thing and that fits into the bevel of the ring. It even has a bearing there, so it must spin while being pressed. I have 2 BMC tool books and 1 Layland tool book, but it's not in any of them. It must be after 1975.
P
PhilW
Let's give it one more try to get a photo in, then i'll give up.
jessebogan
Hello Phil,
These are two parts of an XJ6 and XJS front spring tool. The large "ring" sits in a recess in the spring pan, and the ball socket sits in the inside of the ring. There is a long threaded rod, and a T shaped handle, a triangular bronze retainer of sorts, and a really thick C clip retainer that goes with it. This should fit all XJ6 from 69 to 87, Series 3 XJ12s, and all XJSs. Hope this helps
Jesse
P
PhilW
Thanks, Jesse,
I can see how that will work. I work in a Jag rest. shop, but all we work on are XK's and E's. They don't have front springs, so this will be just another thing in a box lot at my estate sale. Hopefully, not too soon.
Phil.
[ QUOTE ]
Thanks, Jesse,
I can see how that will work. I work in a Jag rest. shop, but all we work on are XK's and E's. .....
Phil.
[/ QUOTE ]
Thats just a terrible terrible thing... /ubbthreads/images/graemlins/cryin.gif
mark
TomMull Wanted Churchill Tool 20sm69 Triumph Classifieds 36
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
aeronca65t Churchill's Land Rover For Sale Rover / Land Rover 1
W General MG 2001 MGF 1.8 Steptronic Flywheel locking tool MG 0
K TR2/3/3A SU balance tool Triumph 13
Editor_Reid MGA Seeking Items for MGA 1600 Mark II Tool Kit MG 0
D New Tool. Restoration & Tools 3
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
charlie74 TR6 handbrake adjustment tool Restoration & Tools 0
Basil Hagerty Car Valuation Tool Other British Cars 1
JPSmit some days your best tool is a credit card Spridgets 2
D My new restoration tool Restoration & Tools 13
Basil Drill Bits (and other tool reviews) Restoration & Tools 9
steveg At last - inexpensive double crimp tool Restoration & Tools 4
Basil Multi-Tool Scraper/ Utility knife Restoration & Tools 0
Basil Now THIS is a tool box Restoration & Tools 6
drooartz The latest tool addition to the shop Restoration & Tools 25
JPSmit Tool identification quiz Restoration & Tools 16
H Wanted BJ8 Jack and complete Tool Kit Austin Healey Classifieds 0
JPSmit what's this tool? Restoration & Tools 12
M TR2/3/3A Transmission Removal Tool Thread Triumph 2
H name and address of Jag tool seller located in Chambersburg pa Jaguar 3
I TR6 Chrome bezel removal tool? Knob removal? Triumph 6
N Tool Rolls and Pouches Austin Healey 14
M TR2/3/3A Cam Bearing Tool Dimensions Triumph 16
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
TomMull Knock Off Tool Restoration & Tools 6
K BMC Supplemental Tool Kit Bags Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
1 MGB MGB tool kit MG 18
D Modified carb sync tool. Austin Healey 11
D Eastwood Surface conditioning tool Restoration & Tools 18
D tool roll Austin Healey 2
M Tool Advice Sought Austin Healey 3
steveg Carb float setting tool Austin Healey 11
H useless carb balance tool Austin Healey 25
steveg Wanted - easy install tool or technique for directional/stop light lenses Austin Healey 9
TomMull bubble flare tool Restoration & Tools 4
TomMull Another tool score? Restoration & Tools 6
PC latest tool score Restoration & Tools 4
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
Jim_Gruber Brake Lines for Bugsy - What do I need for a Flaring Tool / Rear Discs for Bugsy Spridgets 39
Michael Oritt SU reaming tool needed Austin Healey 7
M SU Jet Centering Tool - A Worthwhile Investment? Spridgets 2
Rut Diff plug tool Spridgets 7
Nelson My new toy/tool Spridgets 3
S TR2/3/3A the 9/16 & ½ tube socket for the tool kit Triumph 13
drooartz Brake flaring tool Restoration & Tools 8
Brinkerhoff TR4/4A TR4A tool kit Triumph 0
2billydavies TR2/3/3A Question about size of Clutch Alignment Tool Triumph 9
