Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
Does the heat shield go in front of (toward the fender), or behind (toward the engine) those insulating blocks that separate the Carbs from the intake manifold?
Mine didn't want to fit unless I put the blocks between the shield and manifold. Otherwise it interfered with the throttle linkage, and the hole for the vacuum line didn't like up.
But ideally, I'd think you'd want it the other way, so the heat absorbed by the shield doesn't get conducted to the carbs.
