TR2/3/3A Car won't shut off with generator connected
mallard
This should be an easy find for me but it's not. The car is positive ground. At first starting I did not have the generator hooked up. Car starts with the starter solenoid or the push start and then shuts off just fine without the generator with the ignition switch. Hook up the generator, car starts but will not shut off with the ignition switch. It must be a wire somewhere but it eludes me so far. I'm done for the day in the garage, it's already 106 degrees. For now I'll study the diagram and try to find my error.
TR3driver
Great Pumpkin - R.I.P
First place I would look is the indicator light on the dash. It should be the only place that the charging system and ignition circuit meet. A short there will keep the engine running.
TexasKnucklehead
I think you have the bare-wire/screws instead of the plug-on connectors. It can be really easy to have a stray strand of wire shorting out at the control box. I'm not sure what problem it would cause, but I think I'd check those connections as well. I soldered the ends of mine because I had some trouble tightening them.
Every few hundred miles, I have to check and re-tighten those screws on the control box. If I didn't like the way it looks, I'd have used the newer style connectors.
M
mallard
Thanks Randall that's where I stopped looking for the day. Getting to hot in the garage, and not easy to get to with a heater installed.
M
mallard
Thanks TK I'll look into that also, not a bad idea about the solder.
TR3driver
I've tried the solder trick, and decided it was counter-productive in the long run. The problem is that the surface of the solder creates a point where the least little vibration in the wire (and what TR3 doesn't vibrate?) will flex the copper far enough to work harden and eventually break. I literally wound up with a solder blob trapped under the screw, and nearly all of the strands broken at the surface of the solder. The bare wire seemed to fare better, at least for me. If you still want to use solder, only solder the very tip of the wire (to keep it from fraying) so that part of the pinch screw still rests on bare wire. Adding heat shrink tubing such that it comes right to the edge of the screw seems to help, but of course doesn't look original.
Those 'Lucar' connectors can be troublesome too. Just a few weeks ago, I found that part of my OD failure on the TR3 was caused by one of those quick connects getting loose over time. Had that problem on one of the Stags too, which was a royal pain to find. That quick connect wasn't loose enough to pull off, just loose enough that it could sometimes vibrate and not make good connection. (I'm sure the oil blowing back from the engine didn't help either.) The OD would just randomly jump out of overdrive, then later back in. I was literally in the process of replacing the solenoid (since everything else had checked out good even during the failure), when I noticed there was just a tiny bit of play in the solenoid ground lead.
M
mallard
Randall I removed the wire for the indicator light from the ignition switch and the car shuts off. Now I have to remove the light to see what's the problem. Thanks for your help.
P TR6 Car won't start after backing out of garage Triumph 21
2wrench TR6 Horny car just won't quit. On top of that, likes diesel. Go figure. Think mechanics Triumph 9
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
P Car won't start Austin Healey 7
scoutll The Midget Won First Place at a Car Show......... Spridgets 12
longbridgehealey No brake lights and car won't turn off?? Austin Healey 20
2wrench HELP! My car won't start. Triumph 65
C Car won't start.... MG 14
Z Crane XR700 help needed, car won't run Triumph 27
T Crypt Car Won't Start. Advice? Triumph 20
R car won't start Austin Healey 12
A &$#*&[% Car Still Won't Start Spridgets 11
roscoe United British Car Club of Sacramento event Austin Healey 2
K TR2/3/3A Using header wrap on a street car? Triumph 5
Rick_Thompson TR2/3/3A Sanford Fl All British Car Show, April 6th Triumph 0
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
A Why is my car making this noise? Other Cars 5
N Wanted Help with car identification Other British Classifieds 2
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
drooartz MGB Any risk rolling car on dry bearings MG 4
mctriumph General TR NEVER start a car with stale gas Triumph 0
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
AngliaGT Today's Car Show Spotted 8
P Where’s the British car? Spotted 4
apbos Help Identify this car chassis Racing 20
mezy some dreamers out there in classic car land Jaguar 8
B How to Get a Proof of Income for a Mortgage or car loan? Other Cars 3
Basil Alfred Hitchcock Frenzy - What car is this? Spotted 6
dougie Use your car as it was meant to be used Austin Healey 15
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
LAW75 Car Trailer Austin Healey 20
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
A General MG 2022 Car Display Geelong MG Car Club MG 2
glemon TR5/TR250 This is The Car Triumph 1
S Well, it is an RWA car Spridgets 2
AngliaGT At Today's British Car Club Meeting Spotted 7
Celtic 77 MGB Car history MG 1
