For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal
UltimateQuestion
Everyone says they are looking for a project – well here it is! I need to let my 1972 GT6Mk3 project go, I just don't have the time, the money and the skills necessary to complete it and I'm not getting any younger. The car was Damson Red with a black interior, it is a rotoflex rear suspension, no overdrive. This is a PROJECT and needs someone who can appreciate what the finished car will be like. I do have a clean title for the car and all the keys. I have started on disassembly and stripping the paint and filler off the car. The floors and sills need replacement and the rear wings are rough, but the frame is good and the drivetrain should be OK, turns over by hand although it hasn't been started since the late 1990's. Transmission and shifter were rebuilt in the past. So I am offering for sale the semi-disassembled car that needs a lot of body work, along with at least $8,000 - $10,000 in mostly new parts I have collected over the years. Included is all the sheet metal needed to complete the repairs – new rear wings, complete passenger and driver side floors, inner & outer sills, and sill strengtheners. I will also include a reprint factory service manual, factory parts catalog, and several other repair & restoration publications. A list of the parts is below. I'm not interested in parting out, you will have to come with a trailer and collect the whole lot. The car is located in Northern Virginia, and I am open to reasonable offers, looking for around $4,000 for the car and parts. I have seen cars that are worse than mine sell for more. And they don't come with all the parts. Someone could make this into a fantastic car. Make me a reasonable offer
Parts included with the car (new unless noted)
Rocker End Cap - LH
Rocker End Cap - RH
LH Inner Sill
RH Inner Sill
LH Inner Rocker Panel
RH Inner Rocker Panel
LH Outer Rocker Panel
RH Outer Rocker Panel
Rear Wing, LH
Rear Wing, RH
Main Floor Panel, LH
Main Floor Panel, RH
Peg, Bonnet Locating - 2
Strip, Rubber, Bonnet Protector - 2
Bonnet Hinge Bolt - 2
Bonnet Hinge Nut - 2
Rivet, Check Strap Guide Spring - 2
Rubber Boot, Check Strap - 2
Rivet, Check Strap - 2
Door Check Strap - 2
Door Hinge - 4
Chassis ID Plate
Front Spoiler, Plastic
Spoiler Mounting Hardware Kit
AMCO Rear Bumper Oreverider Bar - Used
Rear Finisher "Horseshoe" LH Black
Rear Finisher "Horseshoe" RH Black
LH Headlight Panel - NOS
RH Headlight Panel - Used
Front Marker Light LH - Used
Front Marker Light RH - Used
Headlight Rim - 2, Used
Headlight Bucket - 2, Used
Bonnet Latch - 2, Used
Bonnet Prop Rod Assenmbly - Used
Bonnet Brace Tube - Used
Bonnet Strength Brace - Used
LH Bonnet Hinge Tube - Used
RH Bonnet Hinge Tube - Used
Washer Jet Assembly - 2
BL House Badges - 2
Door Handle Set - Chrome with keys
Front Valence Bonnet Seal - 2
Rear Bonnet Seal
Sill Weatherstrip - 2
"A" Post Weather Strip - 2
Windscreen Seal
Headlight Gasket - 2, Used
Petrol Filler Cap Gasket - Used
Gasket Set, Wheel Arch
Door Handle Gasket Set
Felt Seal, Oil Dipstick,
Gasket, Fuel Pump to Block
Oil Filter Element
ROTOFLEX Couplings - 2
Bolt Kit, ROTOFLEX
Halfshaft U-Joint - 2
Valve Cover Gasket
Driveshaft U-Joint - 2
Fan Adaptor/Damper
Fan, Plastic (USA Only)
Fan Bolts
Fan Adapter Bolts
Fan Belt
Radiator Bypass hose
Radiator Bottom Hose
Radiator Top Hose - 2
Thermostat, Summer
Thermostat Housing Gasket
External Oil Feed Kit
Filter Cooler Adapter Kit, SS Hoses
Radiator, Oil Cooler, 13 Row
Cable, Heater Water Valve
Sleeve, Cable Water Valve
Headlight Switch, Lucas
Ash Tray
Radio Block Off Plate
Dash Fascia, Wood, 3 Piece - Used
Trans Tunnel, Plastic
Trans Tunnel Hardware Kit
Trans Tunnel Seal Kit
Standard Carpet Set
Luggage Floor Carpet
Rubber Floor Mats
Spare Wheel Clamp Disk
Spare Wheel Hook Bolt
Spare Wheel Wing Nut
Window Crank - 2
Upper A Arm Bolts - 4
Lower A Arm Bolts - 4
Lower A Arm Nuts - 4
Upper A Arm Nuts - 4
Grease Fittings - 2
Steering Rack Gaiter RH
Steering Rack Gaiter LH
Steering Rack Mounts 2
SPAX Adjustable Dampers, Front - 2
Lower Shock Bolts - 2
Lower Shock Nuts - 2
Wheel Bearing Kit, Front Hubs
Sway Bar Bush Kit, Poly
Sway Bar Mount & Bush Kit
Steering Column Bush Kit
Rear Suspension Bush Kit
Radius Arm Bush - 4
Innner Wishbone Bush - 2
Outer Wishbone Bush - 8
Outer Wishbone Water Seal - 8
Outer Wishbone Spacer - 8
Outer Wishbone Dirt Seal - 8
Outer Wishbone Nuts - 2
Rear Wheel Bearing Kit
SPAX Adjustable Dampers, Rear - 2
Upper Shock Nuts - 2
Radius Arm Bolts - 4
Brake Pad Retaining Kit
Semi-Metalic Brake Pads, Set
Anti-Squeal Kit
Brake/Clutch Pedal Return Spring - 2
Pressure Warning Switch
Boot, Pedal Brake/Clutch - 2
Stainless Steel Brake Hose Kit
Copper Nickel Brake Line Kit
Girling LMA Brake Fluid
UltimateQuestion
UltimateQuestion
OK, I'm going to advertise this deal on eBay and/or Craigslist. It is a must sell situation, I am moving/downsizing and its unlikely I will have a garage. Make me an offer!
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
I MGB Purchase of 1972 MGB Roadster MG 3
S MGB-GT 1972 GBT overheating MG 10
R MGB 1972 MGB Defroster Hose MG 2
C TR6 Ignition Switch for 1972 TR6 Triumph 1
tr6nitjulius General TR Sound of 1972 TR6 engine! Triumph 3
tr6web TR6 No spark 1972 TR6 Triumph 35
M 1972 Midget Seat Belt Replacement Spridgets 4
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
D TR6 1972 TR-6 Fuel Vapor Recovery System Triumph 4
W ash tray for a 1972 MGB, MG Classifieds 5
C 1972 Honda N600 Other Cars 4
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
M 1972 Midget Engine Issues Spridgets 10
M General MG 1972 Midget cylinder pitting MG 19
S For Sale Aston Martin DBS V8 Factory Workshop Manual – 1967 - 1972 Models. Other British Classifieds 0
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
edkap2002 TR6 1972 Blowing fuse fed by white wire Triumph 6
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
JPSmit Spotted - 1972 Ambulance Other Cars 5
N TR6 gear reduction starter wiring connections for 1972 TR6 Triumph 1
D MGB-GT 1972 MGB Cloth Seats [Original?] MG 1
2 1972 TVR Vixen 2500 Radiator TVR 6
bcliff For Sale 1972 Austin Mini for sale Other British Classifieds 0
W TR6 1972 or 1973 TR6 Triumph 9
N TR6 found a Soft top frame from a 1972 for sale Triumph 2
A TR6 1972 ignition buzzer Triumph 2
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
B Got permission to sell Audry's 1972 Clubman British Motor Corp 3
B How to sell a RHD 1972 Mini Clubman British Motor Corp 3
U New York City in 1972 Spridgets 18
B XJ-6 [1972] Emmision Problem Jaguar 4
B TR6 1972 TR6 with "A"OD, issue with shift cover Triumph 4
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
S TR6 Help installing the Gear Box 1972 Triumph TR6 Triumph 13
Psevins GT6 1972 GT6 Steering Column Triumph 3
A 1972 MG Midget/Dragonfly Roadster MG 2
B TR6 1972 tr6 orignality question Triumph 3
C Jackie Stewart's Tyrrell F1 Car [Monaco GP 1972] Racing 1
TLW1958 TR6 1972 TR6 No ignition cut off Triumph 2
T 1972 tvr 2500 TVR 3
Gliderman8 1972 Honda Z600 Coupe Spotted 21
W TR6 how to lowering 1972 TR6 soft top Triumph 4
S TR6 Hood insulation for 1972 TR6 Triumph 3
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
HerronScott 1972 Warshawsky catalog Triumph 7
AngliaGT 1972-'79 Midget Parts Spridgets 7
