For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts
UltimateQuestion
I need to let my 1972 GT6Mk3 project go, I just don't have the time, the money and the skills necessary to complete it and I'm not getting any younger. This is a PROJECT and needs someone who can appreciate what the finished car will be like. I do have a clean title for the car and all the keys. I have started on disassembly and stripping the paint and filler off the car. The floors and sills need replacement and the rear wings are rough, but the frame is good and the drivetrain should be OK, turns over by hand although it hasn't been started since the late 1990's. So I am offering for sale the semi-disassembled car that needs a lot of body work, along with at least $8,000 - $10,000 in mostly new parts I have collected over the years. Included is all the sheet metal needed to complete the repairs – new rear wings, complete passenger and driver side floors, inner & outer sills, and sill strengtheners. I will also include a reprint factory service manual, factory parts catalog, and several other repair & restoration publications. A list of the parts is below. I'm not interested in parting out, you will have to come with a trailer and collect the whole lot. The car is located in Northern Virginia, and I am open to reasonable offers, looking for around $4,000 for the car and parts.
Parts included with the car (new unless noted)
Rocker End Cap - LH
Rocker End Cap - RH
LH Inner Sill
RH Inner Sill
LH Inner Rocker Panel
RH Inner Rocker Panel
LH Outer Rocker Panel
RH Outer Rocker Panel
Rear Wing, LH
Rear Wing, RH
Main Floor Panel, LH
Main Floor Panel, RH
Peg, Bonnet Locating - 2
Strip, Rubber, Bonnet Protector - 2
Bonnet Hinge Bolt - 2
Bonnet Hinge Nut - 2
Rivet, Check Strap Guide Spring - 2
Rubber Boot, Check Strap - 2
Rivet, Check Strap - 2
Door Check Strap - 2
Door Hinge - 4
Chassis ID Plate
Front Spoiler, Plastic
Spoiler Mounting Hardware Kit
AMCO Rear Bumper Oreverider Bar - Used
Rear Finisher "Horseshoe" LH Black
Rear Finisher "Horseshoe" RH Black
LH Headlight Panel - NOS
RH Headlight Panel - Used
Front Marker Light LH - Used
Front Marker Light RH - Used
Headlight Rim - 2, Used
Headlight Bucket - 2, Used
Bonnet Latch - 2, Used
Bonnet Prop Rod Assenmbly - Used
Bonnet Brace Tube - Used
Bonnet Strength Brace - Used
LH Bonnet Hinge Tube - Used
RH Bonnet Hinge Tube - Used
Washer Jet Assembly - 2
BL House Badges - 2
Door Handle Set - Chrome
Front Valence Bonnet Seal - 2
Rear Bonnet Seal
Sill Weatherstrip - 2
"A" Post Weather Strip - 2
Windscreen Seal
Headlight Gasket - 2, Used
Petrol Filler Cap Gasket - Used
Gasket Set, Wheel Arch
Door Handle Gasket Set
Felt Seal, Oil Dipstick,
Gasket, Fuel Pump to Block
Oil Filter Element
ROTOFLEX Couplings - 2
Bolt Kit, ROTOFLEX
Halfshaft U-Joint - 2
Valve Cover Gasket
Driveshaft U-Joint - 2
Fan Adaptor/Damper
Fan, Plastic (USA Only)
Fan Bolts
Fan Adapter Bolts
Fan Belt
Radiator Bypass hose
Radiator Botoom Hose
Radiator Top Hose - 2
Thermostat, Summer
Thermostat Housing Gasket
External Oil Feed Kit
Filter Cooler Adaptor Kit, SS Hoses
Radiator, Oil Cooler, 13 Row
Cable, Heater Water Valve
Sleeve, Cable Water Valve
Headlight Switch, Lucas
Ash Tray
Radio Block Off Plate
Dash Fascia, Wood, 3 Piece - Used
Trans Tunnel, Plastic
Trans Tunnel Hardware Kit
Trans Tunnel Seal Kit
Standard Carpet Set
Luggage Floor Carpet
Rubber Floor Mats
Spare Wheel Clamp Disk
Spare Wheel Hook Bolt
Spare Wheel Wing Nut
Window Crank - 2
Upper A Arm Bolts - 4
Lower A Arm Bolts - 4
Lower A Arm Nuts - 4
Upper A Arm Nuts - 4
Grease Fittings - 2
Steering Rack Gaiter RH
Steering Rack Gaiter LH
Steering Rack Mounts 2
SPAX Adjustable Dampers, Front - 2
Lower Shock Bolts - 2
Lower Shock Nuts - 2
Wheel Bearing Kit, Front Hubs
Sway Bar Bush Kit, Poly
Sway Bar Mount & Bush Kit
Steering Column Bush Kit
Rear Suspension Bush Kit
Radius Arm Bush - 4
Innner Wishbone Bush - 2
Outer Wishbone Bush - 8
Outer Wishbone Water Seal - 8
Outer Wishbone Spacer - 8
Outer Wishbone Dirt Seal - 8
Outer Wishbone Nuts - 2
Rear Wheel Bearing Kit
SPAX Adjustable Dampers, Rear - 2
Upper Shock Nuts - 2
Radius Arm Bolts - 4
Brake Pad Retaining Kit
Semi-Metalic Brake Pads, Set
Anti-Squeal Kit
Brake/Clutch Pedal Return Spring - 2
Pressure Warning Switch
Boot, Pedal Brake/Clutch - 2
Stainless Steel Brake Hose Kit
Copper Nickel Brake Line Kit
Girling LMA Brake Fluid
tr6nitjulius For Sale "PRICE REDUCED" 4Sale: TR6 (L/R) taillight assembly Triumph Classifieds 0
zimmy reduced price on my midget Spridgets 9
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
K TR2/3/3A Rebuilding an Engine?..New Cam Sprocket & Gear...1/2 Price Triumph 0
S Price check on TR3A valve cover Triumph Classifieds 0
G TR2/3/3A Valvoline VR1 price Triumph 3
S TR4/4A Fair price for a crankshaft? Triumph 2
Healey Nut If you want a M but cant afford the real M price tag Austin Healey 24
K For Sale TR3 Wheel spacers...Never Used...1/2 Price Triumph Classifieds 0
Morris Price drop Spridgets 1
Bmekosh TR6 Fair price for this car? Triumph 16
B For Sale 1959 Austin Healey, Bugeye Sprite with 74k Miles Price Drop- NEED TO SELL Spridgets Classified 0
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
W At this price..... Spridgets 3
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
jlaird Miss Agatha has a new price Spridgets 45
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
PAUL161 General MG Automotive Paint Price! MG 13
1 Price for original 57 100-6? Austin Healey 22
Editor_Reid T-Series Original Price in US Dollars for an MG TF 1500 MG 4
W Good price on Pacesetter Monza Muffler Spridgets 0
sqbsprite What will be the real price? Spridgets 11
B Hard Top Price Guestimate Spridgets 1
J Help me price my Bugeye? Spridgets 37
PAUL161 T-Series Engine rebuilds going up in price! MG 14
Jim_Gruber BE Bonnets - OMG the price Spridgets 5
J TR6 Is This a Fair Price for TR-6? Triumph 25
BoyRacer BN2 bellhousing - how rare - price? Austin Healey 2
G [Price] King Midget ? Spridgets 12
K Reasonable price for a Morris Minor project car? Other British Cars 4
HCE What is a fair price for a ’69 XKE? Jaguar 19
aeronca65t Replica Price Lotus 3
C What is a fair price for a Caterham? Other British Cars 2
Rut Fair price for a Midget? Spridgets 10
M Healey 3000 Mild Steel Exhaust good price Source Austin Healey 2
D TR6 TR-6 Steel Hardtop -- fair price? Triumph 4
G Fair price on O/D switch and knob? Triumph 5
CZ_Dave Yippeeee 1/2 price day at MG 0
dougie Clapped-out race car....record price? Austin Healey 3
W The price on this bonnet..... Spridgets 9
W What's a realistic price.... Spridgets 14
2 TR6 Price Reduces on 1974 TR6 W/Ovewrdrive. excellent Triumph 0
N Hate to price parts? Triumph 4
Tinkerman 1975 MOSS price sheet Triumph 9
Team_Sprite Isetta as prize on 1957 "Price Is Right" footage Other Cars 0
Gray_Cat The Price is Right... Spridgets 1
V BN-7 Price Austin Healey 49
