Car will not re-start after a drive - Help.
vping
Bronze
I took the GT out for a drive just now. She started right up & I went to the gas station for 4 Gallons. )Reason is I just put a sending unit in it finally and I wanted to see how it registers) Any I drive over to visit the Mrs. at work adn it is 8 miles away 90% highway speed.
I park drop off her wallet & get back in no more than 8 minutes later. It will not start. I hear the pump ticking away but it never stops ticking. As I turn it over you can hear little tiny pops like she is trying to start but it won't. I get out and look at the glass inline filter - No gas. I turn it back on & hear the pump so I wiggle the fuel line a bit and it starts to fill the filter. I tap around the bowls a bit thinking I have a stuck float or something. Pumps stops ticking so I get back in and try and start it. It starts hard and I have to quickly give it gas to get it running. Pop it in gear and I am headed for home. I make it home but I'm puzzled.
Temp hear is 75º, sunny & almost no humidity. This has never happened before.
What gives?
vping
vping
Bronze
I re-named the post to see if it will help.
tony barnhill
Great Pumpkin - R.I.P
So, you've narrowed it down to fuel delivery - have you checked those floats? What about the diaphragm in the fuel pump itself?
vping
vping
Bronze
Hmmm did not think of the pup but...
Problem would be Diaphram ripped which causes Fuel delivery problems but why does it start right up cold?
Floats - would they be stuck and why only warm? To solve it, do I need new floats, needles & seats?
Steve_S
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] I turn it back on & hear the pump so I wiggle the fuel line a bit and it starts to fill the filter.[/QUOTE]
Which fuel line? If it's the fuel line before the pump then the line has a leak.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]I tap around the bowls a bit thinking I have a stuck float or something. Pumps stops ticking so I get back in and try and start it. It starts...[/QUOTE]
Stuck float. Remove the offending float and check it for smooth travel. Make sure there is no friction in any part of its travel. Old gasoline may have varnished on the pivot shaft, causing it to stick before fully open. Still, the car will likely run (very poorly) even on one carb, so that may not be the only problem.
The lack of fuel in the filter leads me to believe it's a delivery problem but tapping on the bowl suggests the float. You may have multiple issues here. My suggestion would be to replace all rubber hoses in the fuel system along with the filter. make sure the filter is AFTER the fuel pump, not before.
If that doesn't solve the problem, move on to float valves and a general cleaning of the carbs. It wouldn't hurt to check the screen in the fuel pump either although that's a bit more involved than the other possible solutions.
zahnej
Did you use Hylomar gasket sealer on the sending unit? I have seen in other posts from a pretty smart guy that Hylomar can plug up a fuel system. Not sure how much it takes to mess things up.
Not familiar with that "B" but early MG's also have a mesh filter at the gas tank where the line goes in.
Steve_S
Hylomar is fine unless you get a bunch of extra oozing into the tank. If a glob breaks loose, it can clog things. The tank itself has a strainer so it's doubtful there is enough extra sealer to block it.
vping
vping
Bronze
Filter is under the hood right before the carbs, glass type with servicable filter insert so it is visable and I just cleaned it out.
Sending unit - Only used rubber gasket and is not leaking presently.
Mesh screen in tank at bottom of pick up tube - Removed as a result of having the tank boiled & etched. Looked like it was in a bad place anyway (do I dare say bad engineering?)
Hoses under hood are all new. Hoses by fuel pump are not.
Varnish - I extensively cleaned every part of the carb when I got the car. How quickly can varnishing start to happen?
jlaird
I think the prob is between the fuel filter and the tank, ie the fuel pump.
vping
vping
Bronze
A leak in one of the lines connecting to the float bowls, should not cause this right? I don't think so. I checked this morning and there was some gas around the inlet. I had to readjust the clamp and all is well. She started with a touch of the key. I let it waarm up a few minutes and then it was still a little hard in starting. I can't see why it would be the pump if, when I am under the hood I can wiggle stuff to ge the fuel filter to fill with gass. It's almost as if there is air trapped in the line's under the hood and when I jiggle it around a bit it purges the air. This sounds silly right?
vping
vping
Bronze
OK still weird. Starts without the choke and runs like a champ. As soon as it gets up to temp & I turn it off It won't start. Acttually right bec=fore I get home it starts acting really strange and sputters like it wants to stall. If I let it sit there without givng it gas, I'm sure it would stall.
Why would the fuel pump be suspect if there is no heat by the pump & it only acts up when the engine bay is hot?
tony barnhill
Is it possible that its vapor locking when it gets hot? How's your carb heat shield? & the gas line heat shield along the edge of the firewall between the engine & gas line?
BIBBER
came in late on this one but couldn't it be as simple as just needing a pressure regulator put in the fuel line in front of bowl? my Spridget is worthless without one..
vping
vping
Bronze
Heat shield is new but there is not any heat shield for the gas line. Never was. I've heard much about it but not paid attention for some reason. What exaclty is vapor lock?
vping
vping
Bronze
BTW here is what the routing of the gas lines looks like.
Steve_S
Fuel boiling in the carbs, lines or in your case fuel pump. It's possible but it would have to be pretty hot in there. Is it that hot in NY right now? You can rule it out next time by propping the bonnet open when you park the car to let the heat out of the engine bay. If it starts up, then there's your problem.
vping
vping
Bronze
It is 68º out right now & I always prop the bonnet open when I come home to do exactly that - cool it off. I've driven it on much hotter days so hot I was sweating bullets and my left foot was burning.
vping
vping
Bronze
Ok. It's been about a half hour. Temp guage read 140º. Turn key on & pump runs & runs. Check filter & not filled with gas. Grav a screw driver & tap float bowls. Filter does not fill & pump is still running. Try and start it and it fires right up instantly and the filter is filled with gas.
Would'nt the pump stop ticking if the syetem was filled with pressure of any sort gas or air? What I guess I don't know is why the system does not hold pressure when not in use unless there were leaks Which I know there are none of under the hood.
BIBBER
just humor me somebody.. really not just a need for a pressure regulator?
Platinum
I think there may be a leak at the inlet side of the pump allowing it to draw air instead of gas. Look to the clamps/connections from the pickup to the pump, Vince. Tho moving the lines around at the filter shouldn't make any difference if that's the case... weird.
mctriumph General TR NEVER start a car with stale gas Triumph 0
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
P TR6 Car won't start after backing out of garage Triumph 21
jfarris TR2/3/3A Rebuilt SU Carbs - Car Won't Start Triumph 7
S TR4/4A Car Will Not Start Triumph 18
P Car won't start Austin Healey 7
BugeyeNJ58 When you start your car, clutch in/out- what gear? Spridgets 27
M Car goes "click" when trying to start - the fix Spridgets 8
Newkie Car wont start sometimes MG 8
M Jump start positive ground car Austin Healey 10
2wrench HELP! My car won't start. Triumph 65
C Car won't start.... MG 14
jjbunn Electrical problem: car wont start Triumph 23
T Crypt Car Won't Start. Advice? Triumph 20
D 1985 xj6 wont start, need help ASAP,no car :[ Jaguar 2
R car won't start Austin Healey 12
A &$#*&[% Car Still Won't Start Spridgets 11
C Car wont start when warm Jaguar 4
7 My car wont start?? MG 9
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
Rick_Thompson TR2/3/3A Sanford Fl All British Car Show, April 6th Triumph 0
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
A Why is my car making this noise? Other Cars 5
N Wanted Help with car identification Other British Classifieds 2
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
tr6nitjulius General TR British Car Mechanic SoCal Triumph 0
B GT6 trying to ID my New Car. GT6 Triumph 6
S TR2/3/3A What are some unusual places you've found parts for your car? Triumph 11
Hamish Racing TR2/3/3A Road trip video - car info Triumph 0
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
drooartz MGB Any risk rolling car on dry bearings MG 4
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
AngliaGT Today's Car Show Spotted 8
P Where’s the British car? Spotted 4
apbos Help Identify this car chassis Racing 20
mezy some dreamers out there in classic car land Jaguar 8
B How to Get a Proof of Income for a Mortgage or car loan? Other Cars 3
Basil Alfred Hitchcock Frenzy - What car is this? Spotted 6
dougie Use your car as it was meant to be used Austin Healey 15
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
LAW75 Car Trailer Austin Healey 20
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
V MGB Zenith Stromberg and a Cat on an earlier model car? MG 22
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
