Bugeye tire size
ichthos
I am finally putting my Bugeye back together after many years of restoration. I know this is probably an old subject, but what is the best size tire for this car? It originally had 145R13 tires, but with the change in the way tire size numbers are expressed now, what would be the best modern equivalent? Thanks for you help.
Kevin
Kevin, what rims and rear ratio are you running?
Pat
For stock rims, 155/80R/13 works fine.
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
John Moore Bugeye Tire Size and Wide White Walls Spridgets 14
B Tire size for a bugeye Spridgets 13
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
5 Original Bugeye Rim and Tire Spridgets 6
AN5Sprite Bugeye Tire Pump? Spridgets 7
I Bugeye tire pump Spridgets 1
I Source for Bugeye tire pump parts? Spridgets 14
Trevor Jessie Gundy Bugeye tire question Spridgets 6
I Tire selection help for Bugeye Spridgets 12
Chatis Tire's [Tyre's] for a Bugeye Sprite Austin Healey 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
