Bugeye Tire Pump?
AN5Sprite
Can anyone confirm this as the proper optional tyre pump that could have come with a Bugeye?
Length of tube is about 14.5"...
I think it is, just looking for a second opinion.
drooartz
Don't know if it is correct, but it sure is cool!
Yes, I know that's not very helpful, but that is a cool little pump. :grin:
smaceng
I will check on the length, the BE pump is the shortest of those Sutty units.
The hose and tire valve connector are not correct: should be a blackish hose with a screw on connector.
I have what I think is the entire BE tool kit.
Scott in CA
smaceng
Here is a picture of what I have. Included in this picture, but was not part of the kit (my understanding reading Horler and the Concourse Guide) are the two lifting hooks and the straight round spanner one might use for the spark plug hex socket. One is supposed to use the hubcap blade tool for that! The following is some description of the kit. Length of the pump is about 12 1/2 inches from the base to the top of the tube.....yours is too large?
From chassis number AN5/501 through AN5/42199 the tool kit was comprised of the following items:
Tool bag
Jack
Spanner, ratchet type to fit jack
Tyre pump
Grease gun
Ignition screwdriver and gage
Tyre valve spanner
Sparking plug box
Feeler gage for tappet and sparking plug (This is a rare original feeler gauge for a Austin Healey 100 BN1. It has two blades one for spark plug gap and the other for valve clearances. The center holder is stamped with the sizes, one side reads SP .025 and the other TC .012. It is in very good condition.)
Screwdriver
Wheel brace (lug wrench) – only disk wheel cars
Knock-off hammer – only wire wheel cars
The lifting jack was triangular shaped and was painted orange-red or black with a zinc plated threaded shaft and unfinished metal lever arm. The jack ratchet tool had a flat straight handle and was either zinc plated or painted black and read “to raise” on one side and “to lower” on the other. The grease gun was unpainted cast aluminum and read “Tecalamit”. The combination screwdriver/ignition gauge was zinc plated as was the tappet/spark plug gauge. The tire valve tool was brass and stamped “Dunlop”. The wire type screwdriver was painted black or left natural. The lug wrench was either black or orange-red. The tire pump was painted black and had a wood handle. The spark plug box spanner was painted black or left natural metal.
Tool Bag
All cars came equipped with a tool bag. These were rectangular in shape (approx. 25 in. wide and 8 in. tall) with a 6 in. tall flap which folded over and had two tie straps heat riveted to the flap. It was made of thin black plastic with heat welded seams. From chassis number AN5/501 through AN5/42199, the tool bags were made of a thin black plastic with no individual pockets.
From AN5/42200 onward, the tool kit had the tool bag, jack, ratched spanner for the jack, spark plug box spanner, tommy bar (straight round bar), lug wrench and hub cap removal lever. Wire wheel cars substituted the knock off hammer for the lug wrench and hub cap lever.
Cheers,
Scott in CACIMG0240a.jpg!B-ICw2QEWk~$(KGrHqIOKjgEzIRR+eYbBM7)bvYlDw~~_12.jpg
BTW.....this is the best info I have.....please don't jump all over me if it is not quite right.
I Bugeye tire pump Spridgets 1
I Source for Bugeye tire pump parts? Spridgets 14
H Can a 175x13 tire be fitted on Bugeye Spridgets 6
5 Original Bugeye Rim and Tire Spridgets 6
A bugeye tire size Spridgets 5
longbridgehealey Bugeye tire size Spridgets 2
Trevor Jessie Gundy Bugeye tire question Spridgets 6
I Bugeye tire size Spridgets 3
I Tire selection help for Bugeye Spridgets 12
John Moore Bugeye Tire Size and Wide White Walls Spridgets 14
B Tire size for a bugeye Spridgets 13
Chatis Tire's [Tyre's] for a Bugeye Sprite Austin Healey 2
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
