Bugeye Starter Switch
NutmegCT
More details and/or a photo might help, but usually, continuity when you push a button means it's working.
Some switches only provide continuity when activated. Some default to continuity, and break continuity when activated.
R
rossco
The pull switch activates the starter. The operator pulls a knob that is attached to a cable that pulls the plunger that causes contact in the switch. They are side by side on the bench. I'm assuming the one showing continuity is working, the other is not. What say you? Sorry, a picture would only be redundant.
NutmegCT
Assuming you have two similar switches, and assuming your starter switch operates like my 1957 Morris ("pull to start"), then yes, if you pull the knob, the circuit will close and bring continuity (and would power up the starter). Which means that one is working.
R
rossco
The new Bugeye starter switch just arrived from Moss. Bridged the terminals with the tester and activated the plunger. No continuity. Is the new switch junk? Don't want to install it if anyone knows for certain. Thanks for answers.
bobhustead
When you say "shorted terminals", I assume you jumped across the starter switch terminals with a screwdriver or the like. If this is so and you got a weak spark, you probably have a weak battery. I assume your starter was working prior to the operation you are in now.
R
rossco
Bob. Yes to your first answer. I think you are right on. Yes, starter was working. Next I'll add a little tension to the fan belt. It may not be driving the gen properly. Thanks for your quick response. R
Rut Bugeye pull starter Spridgets 10
TulsaFred Bugeye starter cable repair? Spridgets 8
D Bugeye starter debugging Spridgets 13
D Bugeye starter, uh, debugging. Austin Healey 3
P Bugeye starter solenoid??? Spridgets 2
B Bugeye Starter Issue & Pics of the Car Spridgets 8
I bugeye starter wire help Spridgets 19
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
I Bugeye starter - is this repairable? Spridgets 8
I Starter help for bugeye please Spridgets 9
Ohiobugeye Bugeye vs. Sprite Mk2 / Midget Mk1 Starter Cable? Spridgets 20
jaegzie No Power [Slow] through starter 59 Bugeye 1275cc Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
I Bugeye charging issues Spridgets 8
I Bugeye smoking Spridgets 9
I Bugeye valve rebuild suggestions Spridgets 8
