Bugeye body panels and replacement
Rut
Who do y'all get your floors and body panels from? I see the floors for sale on Ebay for $89-$99 and wonder if they are any good. Thoughts?
Thanks, Rut
Re: Bugeye body panels
Rut,
Need to be careful as some of the floors available need to be modified for the BE Gas Pedal mount. Who makes a correct replacement floor, AH Spares?
Jim,
Thanks for the heads up, but I plan on using a 1500 gas pedal to give my 12.5s a little more room. I've started drilling out the spot welds and a few panels have started to separate. Since the damage to my existing floors is on both sides and there's some damage to the floor reinforcement as well as the brace that goes over the spring boxes I plan on replacing it all. That said, how do I support the car on jack stands in the rear while removing metal?
Thanks, Rut
Rut
Is your car stripped down? I think you will find it easier removing the floors with the car on its side or upside down. I used the ebay panels for patches for my B/E since I only needed to repair the driver side foot area. I have a passenger side in the box for cheap if you want. The quality is ok, but you can see the difference from the originals. No vents, for a 1500, some holes will have to be drilled.
Paul
Has anyone used Little British Car Co./Vintage Motors for floor pans or replacement tin? If so, can you tell me your experience?
Thanks, Rut
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
H Bugeye Windshield to Body Gasket Spridgets 1
Rut Bugeye windshield to body seal Spridgets 8
Rhodyspit75 Working on the Bugeye body Spridgets 19
W Likely need a few Bugeye inner body panel parts Spridgets 0
R Media blasting a Bugeye body Spridgets 8
R Media Blasting a Bugeye Body Austin Healey 7
J Confused about Bugeye windshield to body seal. Spridgets 15
I Bugeye windscreen frame to body seal Spridgets 1
D Where to start on Bugeye body? Spridgets 17
M Bugeye body number Spridgets 4
abarth69 Square body sprite with Bugeye rear bumpers Spridgets 14
I Bugeye body weight Spridgets 5
kcbugeye1275 Brought the bugeye home from the body shop Spridgets 8
E Bugeye Body Blast Spridgets 24
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
