Where to buy Bugeye Body Panels?
60Bugeye
Hi,
I'm looking at Bugeye body panels (interior and exterior) on the 4 major parts suppliers (Moss, Moss Europe, VB, AH Spares). The prices are mostly equivalent, even with the pound/dollar conversion, though shipping would obviously be higher from the UK/Europe.
In your opinion and experience, which supplies the best quality (including fit) panels?
Cheers,
- Chris
markberry
Hi Chris,
I think all three of those suppliers get their panels from the same vendors. I had good and bad experiences with all three. AH Spares carries a larger selection and their prices were lower, even with the higher shipping rate.
regards
Mark
60Bugeye
60Bugeye
markberry said:
Hi Chris,
regards
Mark
Thanks, Mark.
Moss Europe lists "original" and "aftermarket" for some of their panels.
Is "original" better?
- Chris
60Bugeye
60Bugeye
Rockers (inner and outer), lower rear fenders, part or maybe all floors (might get away with fabricated patches), lower outer front door pillar skin, maybe part of the bulkhead. There may be more as I start tearing the car apart.
I think there are a few manufacturers depending on the panel in question. BMH I think is usually "original" and steelcraft and such are usually "aftermarket".
Someone else may want to correct me, because this is just a generalized assumption of mine.
60Bugeye
60Bugeye
Forgive my ignorance; what is BMH? :smile:
Jim_Gruber
British Motor Heritage
Whitephrog
Chris
I have a pair of new rear end caps (left and right) same as Moss P/N 452-160 and 452-165. These are from AHSpares. Yours for $12.00 including postage if interested.
60Bugeye
60Bugeye
Whitephrog said:
Chris
Sold. I'll PM you.
markberry
60Bugeye said:
markberry said:
Hi Chris,
regards
Mark
Thanks, Mark.
- Chris
I'm not sure what they mean by that. I don't remember ever seeing a choice.
ralph_s
I'm about 95% complete w/ my sheet metal resto on my BE and I'd recommend the "heritage" parts. They are more expensive, but a very good fit.
Bought most of my stuff from Moss, just watch for sales or specials. You can save some $$'s
60Bugeye
60Bugeye
Thanks!
I don't see any "heritage" panels for BE's on the Moss website; only a handful for mini and MGB/C.
Did you call them direct and order or was this from the Moss Europe site?
Cheers,
- Chris
ralph_s
Called direct, floor panels,back shut panel & RR qtr panel were marked heritage. The LR quarter was out of stock.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
