where to buy springs
RobSelina
I've figured out what I want for the front of the 1500. I want 1.5" lowered springs (they'll actually raise the front 0.5" in my case) with a 330lbs (give or take) spring rate. I'm having trouble finding something like this. I've e-mailed speedwell, but no reply. VB and Moss have lowered springs, but no specifications on spring rate or actual ride height changes, so I'm shying away from them at this point. Advice?
Thanks, /ubbthreads/images/graemlins/thumbsup.gif
Rob
aeronca65t
These guys have various springs for your car. No prices on their website (you have to call to makes an order) but I'm pretty sure that they are about $130 a pair (USD).
https://www.spridget.com/
Matthew E. Herd
Moss offers 340 lb/in and 400 lb/in springs. The winners circle (I talked with them recently on this) may have some in stock as they placed an order. In the catalog from Moss, they say expect 6 weeks for delivery for the 400 lb/in springs. They run about 65 dollars a set. VB probably offers something similar, but I forget. Its the rear springs that are expensive. Moss offers 1" lowered for something like $140. All in all, still inexpensive. How did you arrive at the determination that the car will be raised .5"? Supposedly the 340lb/in springs offer a marginal lowering and the 400lb/in springs lower the car approx 1." Since the actual unsprung length of the stock springs (at 271 lb/in according to the Haynes manual) doesn't vary significantly from model to model (approx .5" from bugeye to rubber bumper), this seems to indicate that the ride alteration should be the same regardless. However the rubber bumper vehicles were raised, I don't believe it is in the spring department. Also, the moss catalog claims that the lowered springs are only for earlier cars. This does not make sense to me as the only difference I can determine is the increase in number of leaves from 5 to 6. The mounting points are unchanged so far as I can determine, so aside from possibly being a bit too weak, they should still be bolt on. If the rubber bumpers are removed, it should not be any different from the earlier cars. I guess that my bumpers weigh approximately 70lbs each. Aside from that detail, the cars are pretty much identical in the suspension department. Correct me if I'm wrong. I'm trying to determine the differences so that I know whether or not those rear springs are viable. I have not consulted the gentlemen at the winners circle, who might know the answer to my question.
RobSelina
RobSelina
My vehicle sits 6.5" from the bottom of the rocker up front to the ground, and 8.5" from rocker to ground out back. Since I'm sitting 2" lower up front, I figure 1.5" lowered springs will net me an additional 0.5" of clearance, in addition to the stiffer spring rate.
As far as Moss' indication that the springs are for chrome bumper cars only, I have no idea why they wouldn't work either. I've been curious myself...
I looked in the winners circle catalog before posting, but they only had springs with a 500lbs rate listed. Do they have other springs in addition to the ones in their latest catalog?
Rob
Bugeye58
Rob, if my feeble memory serves me correctly, the free length of the rubber bumper springs is longer than the chrome bumper ones. I show 9.4" for the earlier springs, but don't have a 1500 reference to go by. The Victoria British springs are 8.8" and 340 lb. for the 5-5081, and 9" and 330 lb. for the 5-5082.
Jeff
RobSelina
RobSelina
good info. I think I'm going to get the 5-5082s from VB since I need a few other things from them on my next order.
Thanks,
rob
Matthew E. Herd
Jeff, that's correct, the free length for the bugeyes is something like 9.4" where the RB free length is something like 9.9 inches at the same spring rate. Also, the winners circle offers moss springs in addition to their own parts. Most likely they would be cheaper and they should have them in stock soon, unlike what moss's catalog indicates about their own supplies.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
T Where to buy Factory Grade Paint? Triumph 6
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
