Where to buy Factory Grade Paint?
TriumphGT6
Member
I'm getting my Triumph professionally painted and was wondering where I would go to get factory or factory grade paint to do the job?
Cost is no longer an issue, as I have come to terms that what I want is going to cost good money to get it done right.
Any links or company names would be greatly appreciated.
Thanks,
GT6
sammyb
Now here's the question: do you want modern factory-grade paint, or the quality of paint used by Standard-Triumph for when your car was new?
This is an important question, because original Triumph paint was of horrible quality, especially in the 50s and 60s. I was griping about the quality of my paint job to a guy here who sold TR2-TR4s new (and sold my car when new,) and his comment was "this car looks so much better than when new. We used to call the paint jobs 'primer coats,' because you could see the metal through the paint from the factory."
My dad's roomate got a TR2 new, and by the time it was off the boat in Seattle, the black paint was totally oxidized.
So, if you want the quality of original specs -- almost any modern auto paint will be above that standard. If you want modern top-quality, then there are many choices based upon what results you're looking for, and the color choice, and the type of finish/gloss etc... (And of course, everyone has their brand preferences.)
Geo Hahn
[ QUOTE ]
...original Triumph paint was of horrible quality, especially in the 50s and 60s...
[/ QUOTE ]
Maybe it varied by year, color, day of the week or whatever... but the paint on my '64 is original and looks great. Shines up to a good gloss and does not show wear-thru on the edges.
Of course there are the nicks and bumps of the ensuing years but nothing to indicate a quality issue with either the original paint or workmanship.
billspit
What you will likely want to use is whatever your body shop has experience with AND can match the factory color codes.
Most any paint you buy in an autobody supply shop these days will be pretty good, but the higher end paint like Sikkens is very costly.
steve99
Sikkens is spendy, but IMHO thats the only complaint you'll hear about it, as long as its applied by a person who knows what they are doing with it.
sammyb
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Geo,
Are you sure that the dealer didn't repaint it? I know this was commonplace, especially on the west coast. Also, there was considerable changing of paint suppliers during the 50s and 60s, so it isn't totally nutty that you might have a really well-painted original.
trfourtune
hey,first do some homework on the type of paint.original and original looking does not have clearcoat, so if you want the original look, no base/clear systems.that takes out all the regular production paint shop practice. enamel that is post sanded and polished (400,600,800,1200)sanded then polished will give an original outstanding look. anything else will look "modern".i have seen dupont eurethane done this way and that is the way i will go with my tr4.(original on the outside, fire breathing monster under the hood and body).
look in the yellow pages under body supplies and you might find someone to buy from direct.in vancouver b.c. can. there is white & peters.
B MGA Where to Buy, What to Buy? Axle Nut MG 9
B Windshield glass, where to buy Restoration & Tools 4
M TR4/4A Where to buy a new crown wheel & pinion for TR4A Triumph 5
55modified TR2/3/3A warning indicator bulbs need replacing where and what to buy? Triumph 4
M TR4/4A Where to buy this aluminium extrusion? Triumph 7
vette Any Suggestions As to Where to Buy a New BJ7 Gasoline Tank? Austin Healey 24
AngliaGT Midget Parts - Where to buy? Spridgets 11
M TR4/4A Where to buy replacement TR4 exterior door handles? Triumph 1
F Spitfire Where to buy Stripe Kit Triumph 1
T TR2/3/3A Where to buy steel TR3A battery box? Triumph 8
MY66AH Where to buy a new crank Spridgets 40
B WHEELS- Where to Buy Triumph 4
B TR2/3/3A where to buy oversize thrust washers for TR3B? Triumph 16
Zitch Leaky SUs where to buy rebuild Triumph 22
D Where in N. Va. to buy/ mounts tires on wire wheel Austin Healey 3
Mychael Where to buy quality pedal rubbers. Spridgets 2
M Where would you buy your next fuel tank? Austin Healey 6
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
60Bugeye Where to buy Bugeye Body Panels? Spridgets 13
T Where buy bullet connectors locally [ie pick up]? Triumph 15
W 90 GL$ Where to buy???? Triumph 12
richberman Where to buy Q-H bushings? Austin Healey 1
PatGalvin TR2/3/3A TR3 Fuel Line - where to buy? Triumph 7
T Where to buy bolts that secure door latch Triumph 10
B where to buy 175/80r15's? Austin Healey 11
P Where to buy a Parts Washer! Restoration & Tools 10
H WHERE TO BUY A CLUTCH M/C PUSHROD? Triumph 5
hondo402000 TR6 ARP Head stud kit 71 TR6[ Where to buy] Triumph 10
D T-Series Where to buy clutch parts MG 5
soren_ak where do u buy your healey parts guys ? Austin Healey 8
Gerdo Fuel Float? Where to buy? Triumph 8
Geo Hahn Redlines - Where to buy Triumph 3
L Where to Buy Replacement Rocker Panels-Frustrated! Austin Healey 5
B TR6 Where can I buy a trunk kit for a TR6? Triumph 6
M Where can I buy my spouse TR6 things - T-shirts? Other British Cars 4
YankeeTR TR2/3/3A Where can you buy TR2 door wood? Triumph 11
B Need Advice: Where to buy...? Spridgets 1
356roadster brake drums for early 100 bn1: where to buy? Austin Healey 16
J Where to buy aluminum door trim. Austin Healey 3
J Where to buy windshield and rubber parts. Austin Healey 5
Z TR6 Where to buy TR6 Soft Top Triumph 7
tr6web Paint - where to buy it? Triumph 3
RobSelina where to buy springs Spridgets 7
K MGB where can i buy mirror for a MGB Roadster 1971 ?? MG 3
V Where to buy headers Triumph 0
Steve Where do you buy tools? Restoration & Tools 14
Scotsman TR4/4A Chimney nuts, where do they go Triumph 5
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
Pythias Where to post FOR SALE Spridgets 1
