Brakes....a little help please?
Chet Zerlin
Hi all!
Here's the issue:
My right rear brake shoes are not releasing but the left rear brakes are fine. When the right is locked up I can use the adjustment bolt to loosen the brake shoe and the wheel turns again but when I then press on the brake pedal it locks up again. Clearly something in the right rear brake is not releasing the fluid pressure.
In my 100-6 there is one main metal line going from the master cylinder to a junction and from there a rubber line goes to a"splitter". From that splitter there are two separate metal brake lines - one to each brake. Since the left rear brake is working fine it's not this rubber line that is the problem because that line supplies fluid to both wheels.
I know that usually the culprit would be a rubber line going to the brake that was collapsing or clogged so as to not release the pressure but since in my car those lines are metal tubes and not rubber could the problem be that the brake "wheel cylinder" inside my drum brake assembly is not releasing the pressure?
Or is it possible that the metal line from the "splitter" that attaches to the "wheel cylinder" the culprit?
Has anyone had similar issues and resolved them?
Anyone know how to test the wheel cylinder?
Thanks for your help!
Chet
TimK
I had a problem with the sliding brake cylinder on one wheel getting cocked and locking up. Check the wheel cylinder for free movement. I think I replaced the clip that the cylinder slides on.
roscoe
I'm with Tim. Ive had the samenthing happen. When you backoff the adjuster a notch and then the brake releases, can you put the adjuster back where it was and have a free wheel? I never did understand how people could suggest that a brake line was collapsing when pressure in the line is really trying to expand it. It would have to be very much deteriorated to collapse at the moment of pressure release but yet be able to keep pressure trapped upstream. I just don't get how that can happen. Also, if pressure were trapped in the line backing off the adjusterwould probably not completely release the brake, the piston would just extend a bit more because the shoe had moved.
aero3113
A line can collapse internally without noticing it from the exterior of the hose. When this happens the piece that has failed (depends on what way the piece collapses) acts like a check valve not allowing the fluid to return and not releasing pressure. I had this happen to a Vette I owned, front right wheel locked up. I loosened the fitting and it released the pressure freeing up the wheel.
C
Chet Zerlin
Thanks for your replies!
When I back off the adjuster it frees up the wheel. When I put the adjust back where it was the wheel is again locked up. So whatever is getting stuck is not "unstuck" and I agree with you that the shoe had moved but the pressure has not been released.
I checked the wheel cylinder for movement and it appears to be solid.....is there anything else can I do to check if the wheel cylinder is ok or not? Or am I now just going to have to dismantle and replace with a new wheel cylinder and hope that's what's wrong?
Chet
red57
Chet, What you are describing is not a stock brake pluming system
The stock system is a steel line from the master to the junction block with the brake light switch and two steel lines going to the front brakes and one steel line going to the rear (there should be no rubber line coming off the junction block) and at the rear end a flex line to the axle and two steel lines to the rear wheels.
In testing for a partially collapsed flex line, you should relieve pressure by cracking the bleed screw but you should not change any adjustment - presumably it was adjusted fine before the problem.
You also say
This is the way it should be - you back off an adjustment and the wheel turns free, press on the pedal and the wheel stops..... I am confused because this is the way they are supposed to work.
Again, if you want to check for residual pressure that is not bleeding back to the master cylinder, just crack the bleed screws and see if that relieved pressure.
Dave
bob hughes
Chet
You say that you have checked the cylinder and it is solid. Do you mean it is solid in the back plate? It should not be, it should slide, as the piston moves out and the shoe is forced onto the drum, the cylinder should slide in the opposite direction forcing the other shoe onto the drum. Take the shoes and springs off and gently tap it with a persuader to see if you can get movement. From time to time I find that mine seize up a little and I have to take the cylinders off and clean the parts up, including the back plate, grease them using copper grease and put it all back together again, a real PITA with the pare of clips at the back holding the cylinder to the back plate.
:cheers:
TimK
I agree with Bob, because that is essentially what I did to solve my problem. I replaced the clips and lubed them with brake grease. The wheel cylinder was getting cocked when it tried to slide and got stuck.
C
Chet Zerlin
Cylinder was the problem - it was frozen. Replaced with a new one and problem solved! Now have to bleed the brakes and should be good to go.
Thanks!
Chet
jlaird Little help - brakes Spridgets 14
Hawk813 TR6 TR6 Brakes Triumph 2
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
I MGB Sticky Rotors/Brakes MG 5
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R Bugeye drum brakes Spridgets 7
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Brakes Not Releasing Austin Healey 9
prb51 100-6 Drum Brakes Austin Healey 9
bighealeysource Drum Brakes Assembly Austin Healey 6
A Drum Brakes Again Austin Healey 18
NutmegCT Morris Minor brakes! Other British Cars 9
BritBite XKE BRAKES Jaguar 1
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
algot1901 Brakes for Anglia / Prefect Other British Cars 2
M TR6 76 TR6 Brakes too tight Triumph 10
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
K TR2/3/3A Sticking front brakes? Triumph 9
B MGA After-market brakes MG 5
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
C TR2/3/3A bleeding brakes Triumph 11
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
A TR6 '74 TR6 no brakes Triumph 14
FlyingCat Spitfire Bleedin' Brakes Triumph 6
R TR2/3/3A Rear Brakes Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
HalLucy Post-War Other 1949 2000 Triumph Roadster brakes Triumph 17
S TR2/3/3A Now the bad news. BRAKES Triumph 7
M TR6 Rear brakes Triumph 2
John_Mc TR6 Front brakes won't release Triumph 20
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
P Brakes lock up when rolling forward Austin Healey 4
P Honda weak brakes Other Cars 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
D TR5/TR250 Squealing brakes Triumph 4
R General Tech Loss of brakes Triumph 11
R 100 Brakes Austin Healey 3
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
B Dual Circuit Brakes Austin Healey 3
B jag brakes Austin Healey 20
S Servicing BJ8 drum brakes Austin Healey 3
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
