Brakes lock up when rolling forward
PHulst
Bronze
My 1959 100-6 has been moved around the shop a bit this winter, the last time being last week. I started it up as usual and moved it from one side to the other and noticed no issues.
Las night I had to move it forward so started it, put it in gear and let out the clutch. In doing so I found that 2 of the 4 wheels (I think both fronts) will not rotate even 1 full revolution before locking up and dragging. I can back up the car by pushing or under power and no problems. I just can't move much forward.
Any thoughts? I may end up trying to back off the adjusters and see if that helps. Otherwise I will put the fronts on wheel dollies in the short term just to move the car.
I thought about a bad brake hose but that doesn't seem like it would affect both sides.
This is a bit of a puzzle.
P
PHulst
Bronze
I suppose its possible. I know that one of the shocks leaks badly, and it’s on the to-do list once I get moving on the car. I haven’t yet seen brake fluid on the floor, though.
RAC68
I agree with John and would suggest a fast look by pulling the drums. This is not a hard or time consuming job and if the linings are wet will tell you their condition. Keep in mind that a very slow wheel cylinder leak can be absorbed into a sitting brake lining without showing any fluid outside of the drum. It is when the shoe is saturated or the leak increases over the absorbtion rate of the shoe that excess fluid is expelled. Since this condition has only recently started, I would expect that the wheel cylinder may have hung up internally or was on the bitter edge of retaining the fluid with this stimulated by cold contracting temperatures.
Keep in mind that this may not ever happened in warmer weather or when the car was actively in use as the heated brakes could have been enough to evaporate the slow seepage.
Hope this helps,
Ray(64BJ8P1)
RestoreThemAll
If the car is sitting for a while the drums can rust where they are not in contact with the shoe. That combined with a drum out of round could cause the brake to drag badly. It could feel like it's locking up. Either way pulling and examining the drums and wheel cyl seems like the best idea. Wheel cyl and calipers can be bad without leaking.
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
Hawk813 TR6 TR6 Brakes Triumph 5
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
I MGB Sticky Rotors/Brakes MG 5
KVH General Tech Rear Brakes and Solid Axle Triumph 2
R Bugeye drum brakes Spridgets 7
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
J Brakes Not Releasing Austin Healey 9
prb51 100-6 Drum Brakes Austin Healey 9
bighealeysource Drum Brakes Assembly Austin Healey 6
A Drum Brakes Again Austin Healey 18
NutmegCT Morris Minor brakes! Other British Cars 9
BritBite XKE BRAKES Jaguar 1
S TR6 1974 TR6 Rear Brakes w/o hydr. press. Triumph 6
algot1901 Brakes for Anglia / Prefect Other British Cars 2
M TR6 76 TR6 Brakes too tight Triumph 10
fundytides Bleeding Lockheed Brakes on 1951 Vanguard Other British Cars 11
K TR2/3/3A Sticking front brakes? Triumph 9
B MGA After-market brakes MG 5
5 TR2/3/3A Seized rear brakes Triumph 9
M TR2/3/3A Difficulty Adjusting Tr3A Rear Brakes Triumph 12
Jeepster Rear Brakes Adjustment Austin Healey 6
C TR2/3/3A bleeding brakes Triumph 11
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
R TR2/3/3A Girling Rear Brakes Triumph 9
A TR6 '74 TR6 no brakes Triumph 14
FlyingCat Spitfire Bleedin' Brakes Triumph 6
R TR2/3/3A Rear Brakes Triumph 9
K TR2/3/3A The flexing front spindle and no brakes syndrome? Triumph 5
HalLucy Post-War Other 1949 2000 Triumph Roadster brakes Triumph 17
S TR2/3/3A Now the bad news. BRAKES Triumph 7
M TR6 Rear brakes Triumph 2
John_Mc TR6 Front brakes won't release Triumph 20
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
P Honda weak brakes Other Cars 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
C 100-6 front drum brakes? Austin Healey 36
D TR5/TR250 Squealing brakes Triumph 4
R General Tech Loss of brakes Triumph 11
R 100 Brakes Austin Healey 3
Trevor Jessie When was the last time you bled your brakes? Spridgets 4
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
B Dual Circuit Brakes Austin Healey 3
B jag brakes Austin Healey 20
S Servicing BJ8 drum brakes Austin Healey 3
C Brakes....a little help please? Austin Healey 9
J Wanted 1950 Austin sheerline A125 need brakes Other British Classifieds 0
C Wanted 3000 Front Disc Brakes Austin Healey Classifieds 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
