TR2/3/3A Boot lid seal.
John_Progess
Is there a correct/best way to install the boot lid seal. I have mine temporarily set on the flange, post 60 K car, and the top of the seal leans/bends toward the center of the boot as opposed leaning toward the outside. Thanks and have a good day!
John
bobhustead
I believe you have it right. I recall that if you put it the other way the lid won't close. Don't glue it til somebody else confirms.
Bob
PatGalvin
As a data point, I installed mine with lip facing outward and lid won't close. I will have to remove and reinstall. But I'm afraid I'll also have to cut it down to fit. I had to cut down the spare lid seal significantly to make it fit. Without cut, it wasn't going to close. The spare lid seal had lip facing inwards.
Pat
bobhustead
I tried cutting down the spare tire door seal and found it impossible to get a straight line. I put the new one on whole, forced the door shut and forced the latches to turn. I left it a couple weeks and it was then usable.
Bob
B Fitting the Boot Lid Seal Austin Healey 8
Got_All_4 TR2/3/3A Is this the proper Boot lid seal? Triumph 9
Tinkerman TR2/3/3A Boot Lid Seal TR3A Triumph 7
Lin Boot Lid rubber seal Austin Healey 10
G Wanted Tr4a boot lid Triumph Classifieds 2
AUSMHLY Boot Lid Identification Austin Healey 2
chicken Boot Lid Badge Austin Healey 8
B TR6 Boot lid thread plates loose in stiffener Triumph 1
A BN2 Boot Lid Austin Healey 4
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
toysrrus TR6 "how to un-lock a boot lid"??? Triumph 11
CLEAH Boot lid repair Austin Healey 2
Y TR6 Triumph TR6 Trunk Boot lid wanted Triumph 4
B Aluminium Bonnet and Boot Lid Austin Healey 6
brcree MGB Trunk lid..[boot] alignement MG 4
R 100-4 boot lid prop Austin Healey 2
PatGalvin TR2/3/3A Boot Lid Reinforcing Supports Question, TR3A Triumph 8
J BN1 Boot Lid Bracket Austin Healey 9
healeyblue Boot lid safety cable Austin Healey 10
angelfj1 TR2/3/3A TR3A - Boot Lid Handle Triumph 6
sundown boot lid Triumph 6
Jim_Newman Trunk/boot lid Austin Healey 9
PatGalvin Rusty Boot Lid Follies Triumph 24
K TR2/3/3A Fitting the TR3 Boot Lid Triumph 4
M BJ7 BOOT LID Austin Healey 6
G I need a Vermillion trunk [boot] lid. Spridgets 3
Tinkerman TR2/3/3A 3A Boot Lid Handle Triumph 4
wangdango adding aluminum to alloy boot lid? Restoration & Tools 0
King_of_England Mk 3 boot lid rubber replacemant... British Motor Corp 4
Lin Luggage Rack Boot Lid Shield Austin Healey 18
J Boot Lid Austin Healey 4
kyreb1862 Boot Lid Adjustment MG 1
Lin Austin Healey Script on Boot Lid Austin Healey 28
69MGC Any tips for fixing a bent boot lid MG 7
John_Mc Second boot lid Triumph 0
weewillie boot lid British Motor Corp 3
kyreb1862 Boot Lid Needs Adjusting MG 19
Ed_K Correct way to fasten the boot lid gasket ? Austin Healey 4
Cain Boot Lid/Bonnet Alignment Triumph 2
Cain TR6 Odd Problem - TR6 Boot Lid Triumph 1
A Adjusting boot lid position Spridgets 5
Editor_Reid Bugeye with a factory [?] boot lid Spridgets 7
Editor_Reid Bugeye with a factory [?] boot lid Austin Healey 1
mctriumph General TR Spring boot sale Umpteenth Annual Triumph 5
5 BJ7 Boot Rust-Through Austin Healey 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
K TR2/3/3A boot drain troughs 59 tr3 Triumph 7
J Restoration Progress - Boot Installed Austin Healey 1
