TR2/3/3A Body Off Restoration on TR3 [long post]
martx-5
OK, I'm embroiled in a complete restoration on my TR3, VIN 23677. The body needs more work then I think is worth putting into, so I acquired a complete (shell and all outer panels) body, but it's a 60k+. That means that there a lot of differences. The biggest problems I've noted to date are listed below.
1. Wiring harness has spade connectors. Are there any other differences in the wiring, other then the connectors??
2. Wedge vs. Dzus fastener side curtains. No problem, I have the late doors and a set of the late side curtains.
3. Interior components. Since I'm completely re-doing the interior, no problem.
4. Different fuel tank. I have both tanks, and both are good. Which one will be the easiest fit using the original fuel lines.
5. This is my biggest problem that I see. Windscreens. I only have the early one. Should I hunt down a later one, or mount the early slider assemblies to the scuttle and use the eary windscreen??
I probably haven't yet seen all the differences that will affect this resto job, so if there are some I've missed, please let me know.
The big external givaway is the raised bosses of the hinges for the bonnet and boot.
Buy a new wiring harness correct for the car, you will never be sorry you did!!!
You should use the latter tank if its serviceable.
Mad dog
Martx -
Ditto what MD said. I'm unaware of any differences in the windscreens and stanchions. Maybe someone else can address that; I was under the impression that they were the same throughout the TR3 production.
Regarding the sidescreens, the dzus mounts were less obtrusive and a bit more positive in their locking arrangements. A big complaint was the wedge mounts being so big as to present a problem with banging one's elbow or knee. Mine haven't been an issue, however.
Mickey
The body of a 60k+ car will require you to use the later fuel tank, otherwise the outlet won't fit (you'd need to bend it.) You'll also want to make sure you get the seat tracks where you like them in the new floors, since with the 60K+ cars you lose 6 inches of possible leg room with the actual package shelf in there. (I'm tall, and liked the leg room in my old 45,396 car as opposed to my 62something car now.
Keep in mind that after 60,000, the car doors no longer had wood frames, so that's a good thing for making sure your lift-the-dot studs stay in.
Other than that, there are a bunch of rolling changes between 20K and 60K (brake drum size.)
As with the windscreen, you either need new sliders or old stanchions...although you're old car might provide the ones you need. The windshields are the same, I believe.
Yes, there are wiring differences... panel light rheostat, wiper motor wiring and inline fuse for lights come to mind. All easily dealt with once you decide which car you're building (23677 or 6xxxx).
If there is a choice, I would prefer the earlier stanchions since they let you slide the windscreen off the car quite easily. I often use an aeroscreen -- but if you are not inclined to do this then it may not matter.
[Mickey - FYI, the later TR3As had a the windscreen bolted in place, i.e. no dzus fasteners & did not slide off.]
[ QUOTE ]
[/ QUOTE ]
I didn't know that! Learn something new every day, don't we? Mine is supposed to slide off, but is REALLY tight. Don't plan to take it off, anyway!
Mickey
I learned the hard way about the stanchions. I bought a pair on ebay about 5 years ago for my '59 and the stanchions turned out to be from a late build car (like a TR3B.) After wrecking one of my dzuz fastners (and scratching my head for about 20 minutes,) I realized the depth of the holes between stanchions (old and new) were different.
But 60,000 is not the change date for stanchions -- and there has been some speculation over the years on where the change actually happened. I've heard "TR3Bs only" and I've heard 1961-era cars, but no specific date -- my late 60 has original style stanchions.
[ QUOTE ]
[/ QUOTE ]
One thing I have learned about these great LBC's is that there weren't any hard and fast dates for changes, and much of what came out of the factories was at the whim of the workers, and what was available at the time.
According to the build records, my TR3 came with blue leather upholstery and no heater. But it clearly had a heater (may have been a dealer installation), and the upholstery was vinyl in the color "stone." When I restored it, I chose a combination that was offered that year, pearl white with red interior. Even if I had wanted to make it "original", it seems I had a choice, and could have made a case in any concours competition.
Mickey
Well, the body that I've acquired definitely has the late style windscreen attachment. I assumed 60k+, as that is when most of the other changes were, and it does have all the other 60k+ changes such as raised hinge plinths, squared off section behind the seats, etc. I do use the aero screens. Why would using the later style windscreen be a problem?? Is it too difficult to remove?? If so, I'll stick with the early style.
Just remember, the only change I'm making is with the body shell itself. All of the other components for this car are for a 23677. I'm not interested in originality. There are enough other TR3's out there to fulfill this role. I just want a fun, reliable TR I can flog around on the weekends.
By the way, this is all great stuff...keep the info flowing.
S TR2/3/3A Frame off vs. body on restoration Triumph 21
Rut TR4/4A On or off frame when welding in body panels Triumph 16
B Final painting of all body panels - with panels on or off car? Pros and Cons? Austin Healey 7
H Michelotti one off body on an E-type? What year chassis and what shop did the work? Jaguar 0
7 Post-War Other Hope I haven't bitten off more than I can chew! [the body is almost off] Triumph 5
M Body off getting repaired [pics] Triumph 10
Tr3aguy TR2/3/3A Help....Time for the body to come off [TR3] Triumph 7
TR6oldtimer Body Work Off Frame Triumph 3
B TR2/3/3A Pulling TR3 body off question Thanks Triumph 15
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
Popeye Taking body off frame Triumph 0
CraigLandrum Assemble and run or body off restore? Triumph 51
G Body off Triumph 4
Mark_Gibson Next Phase Complete, TR-2 has Body OFF! Triumph 6
Patton Paint and Body -Getting it ready to send it off Austin Healey 10
TypeRboy Wellthere's nothing for it... The body comes off! Lotus 3
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 7
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
