Body gap filler recommendation
TR6oldtimer
The TR6 (and others) body was sealed in a lot of places with a rigid putty or filler of some sort. I am not referring to seam sealers, but large gap fillers. For example the upper and lower rear B post, or under the forward and rear deck seam.
For those of you doing your own body restorations, what products and/or techniques are you using to seal these areas?
As an MG owner, I don't know what "large gap" means. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
<runs to hide behind th' couch>
I'm restoring my '76 TR6 currently. I plan to use regular body filler (i.e Evercoat brand) to fill those gaps.
L For Sale Austin Healey Body Panel Austin Healey Classifieds 2
S TR2/3/3A body panel fitting Triumph 8
D TR6 lost body shell Triumph 1
J Can a TF engine be installed in a TD body? MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
5 MGA Body and Chassis Separation? MG 2
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
Bayless How does '67 Sprite top attach to body? Spridgets 3
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
1 TR2/3/3A Best Rustproofing for inside of body. Triumph 7
K TR2/3/3A The "wide body" TR3? Triumph 6
W TR2/3/3A Interior and Body Colours Triumph 14
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
D Body/Paint Shop Recommendations Austin Healey 1
apbos TR5/TR250 TR250 rolling chassis and body for sale Triumph 3
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T For Sale Free - Body Jig for TR3/TR3A Triumph Classifieds 6
M BJ8 Inner Body Panel Repair Austin Healey 2
T TR2/3/3A Body Tub Weight Triumph 8
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
D TRIUMPH TR6 BODY SHELL Triumph Classifieds 1
B After bead blasting the body I noticed some interesting things… Spridgets 2
S Inner Body Alignment Austin Healey 0
B Body Reassembly Austin Healey 2
S TR2/3/3A Body Mounting Bolts. Triumph 14
F TR2/3/3A front body mounts Triumph 7
jdubois GT6 After over two years stalled at the body shop, my GT6 is starting come back to life! Triumph 5
Csarneson Body panel assembly order? Austin Healey 6
J Wanted WTB Triumph TR6 Body/ Rolling Chassis Triumph Classifieds 0
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
nichola TR6 Recommendation for tail lamp to body gasket Triumph 16
X Production year based on body number ? TVR 3
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
S For Sale Austin Healey Sprite and MG Midget Factory Body Parts Manuals - 1958 - 1974 Austin Healey Classifieds 0
J For Sale La Dawri 'Del Mar' fiberglass body for TR-2 thru TR-6 Other British Classifieds 1
T For Sale MGB Pull Handle Tub Body Shell for sale MG Classifieds 0
BJ8Healeys Body Parts Code Austin Healey 5
BOBBYR Body Panel measurements and angles Austin Healey 6
S TR2/3/3A Frame off vs. body on restoration Triumph 21
B Longbridge 100-6 Windshield Posts - Body Color or Silver? Austin Healey 16
A Recommendations for body repair near NYC Restoration & Tools 2
H GT6 Replacement body panels Triumph 4
Jim_Stevens TR2/3/3A Rear fender stays: black or body color? Triumph 8
