BN-1 Crossrod Needed but not available.
gluedup
I'm not able to find a crossbar for my 1955 BN-1. I plan on having one fabricated. I'll either bore the tapered holes to fit common rod ends or use available british spec ends and have the rod threaded to match. Any advice or experience would be appreciated. If anyone has a crossbar or knows someone who has a crossbar for sale I'll buy it.
Thomas Davis
Okay, I've got to ask--what is a "crossbar"? Bob seems to know and it sounds like a suspension component, but I am not familiar with the term. If perhaps it is a front anti-roll bar, I have a stock one that I would be happy to part with.
Hi Thomas,
Welcome to the Forum. Have you tried Hemphill, which is local to you for a used part? You could also check British Car Specialists in California.
Hi Thomas,
I believe Gary Hemphill--'Hemphill's Healey Haven,' right?--went out of business years ago. Would love to hear otherwise.
ps. I too was stumped by 'crossbar.' More common term, perhaps, is 'center tie rod.'
That toe adjuster thingy.
Oh, THAT thingie, which I always called a tie rod....
Sorry, I only have one of those and it is in service right now.
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
H TR2/3/3A Rock guard needed Triumph 2
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
M General MG Wire Wheel Specialist Needed in Los Angeles area MG 0
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
P MGB Zenith water choke gasket needed MG 4
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
T Wanted BJ7 parts needed Austin Healey Classifieds 0
Jim_Gruber Bugeye Seat Pans needed Spridgets 1
AUSMHLY BJ8 Second Gear Needed Austin Healey 16
E GT6 Help electrical guru needed Triumph 4
Joel Lester TR2/3/3A What size speedi-sleeve needed for pinion seal on a TR3? Triumph 6
tr6web TR6 More leg room needed Triumph 5
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
R Rust in Block? Help needed! Austin Healey 6
steveg TR6 Hood release pictures needed Triumph 22
steveg Picture needed - front turn light Austin Healey 4
steveg TR6 Spec needed for correct ride height Triumph 28
Michael Oritt 100 throttle linkage--help needed Austin Healey 3
Mickey Richaud TR4/4A TR4 Head Needed Triumph 4
D New Battery Needed for BJ8 Austin Healey 9
Michael Oritt Tenax fastener source needed Austin Healey 6
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
N Electrical Troubleshooting Advice Needed Spridgets 6
Jim_Stevens TR2/3/3A Quick measurement needed Triumph 4
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
D Wanted Needed for 1954MGT. MG Classifieds 1
Michael Oritt Speedi-sleeve p/n needed Austin Healey 7
2 Wanted SU-h6 Carb. BODY ONLY needed, badly worn. for TR3A Triumph Classifieds 5
J BJ8 Turn signal help needed. Austin Healey 6
F Water pump replacement on my BT7 advice needed please Austin Healey 18
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
Got_All_4 General TR Is there a special tool needed for rear brake cylinders Triumph 14
R Our J-H plan - torque specs needed! Other British Cars 2
Jim_Stevens TR2/3/3A Door capping—batting needed? Triumph 9
M Modern Paint Code Needed for Honolulu Blue Restoration & Tools 1
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR6 part needed Triumph 2
T C42 BJ8 generator long screw needed Austin Healey 2
Michael Oritt Healey image needed Austin Healey 13
Michael Oritt Torque values needed for 100 Austin Healey 5
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
