AUSMHLY
Is my car doing something that is making the shocks leak? Or do I have incredibly bad luck.
Here's the time line.
5.10.10 bought left and right remanufactured lever shocks from World Wide Auto Parts.
8.26.10 right shock leaks. Replacement sent and installed.
2.24.11 right shock leaks. Replacement sent and installed.
6.18.12 right shock leaks.
When installed, all shocks were bolted down tight and travel was smooth. Checked the right shock today, 6.18.12 all four bolts are tight, travel is smooth.
What should I look into?
Why is this happening to the right side only?
The leak is coming from the left side of the shock, where it rotates.
