trunk floor pan replacement 1964 BJ8
Hubert Holloway
I have a new floor pan to be installed in the trunk. I can see all the rivets around the back shroud, but how is the pan attached to the inner fenders at the sides? Rivets, Bolts, or welded? Also, anyone know a source for the replacement rivets?
Originally, I believe it was spot-welded. I recall having to air-chisel mine apart.
BCS sells the rivets, but I believe they need to be cut to length. Aircraft Spruce sells a variety of rivets you can choose from, but I don't think I've ever seen the exact same head as the originals, which were halfway between 'pan' and 'rounded' (same with the BCS ones).
RAC68
Hi Hubert,
The pan is welded to the inner fenders. The only thing riveted, that I am think of in the boot area, is the shroud.
Enjoy the rebuild,
Ray(64BJ8P1)
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
R TR2/3/3A Trunk floor replacment Triumph 4
R TR2/3/3A Boot/trunk floor Triumph 5
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
M BN1 trunk floor question Austin Healey 4
J Rear part of trunk floor availablity? Spridgets 17
apbos TR2/3/3A TR3a Trunk floor removal and replacement Triumph 20
T MGB-GT Anyone need a BGT replacement trunk floor? MG 0
A BN7 trunk floor markings Austin Healey 10
martx-5 TR2/3/3A TR3 Trunk Floor Triumph 0
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
1 Wedge Breaking Into a Trunk Boot Triumph 3
S TR2/3/3A tr3 trunk primer Triumph 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
S TR2/3/3A T handle trunk lock Triumph 14
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
