Battery Booster/Jump Starter
Lynn Kirkpatrick
I'm looking for another jump starter, or battery booster. These are the portable/rechargeable gizmos that can be connected to a low battery to start a LBC/car/truck/etc. Any suggestions?
I bought one at a parts store that lasted 6-8 months with light usage. When it quit holding enough charge it took it back and they replaced it under warranty. Now the 2nd one is belly up and I would like to either get a good one, or a cheap one that will start a V-8 and then when it quits I won't feel bad about it not lasting.
I don't need the air compressor (they tend to overheat) or all of the outlets. I would prefer to speend less than $100, but if I can find a good one I may spring for it.
What amp rating is needed? I think I had one rated @ 1000 amps, peak, that would start my truck, MG, etc, but that may have been more than I need. Any suggestions?
Thanks
Deleted member 8987
The internal sealed lead acid batteries (like a motorcycle battery) go bad.
In the use these get, they sulphate out fast.
I have one they tried to leave on charge to bring it up....fried the electronics, took out the power supply (it's a 12V wall wart inside).
You're better off with a good battery charger and a long extension cord, in my experience.
jsfbond
This is where quality comes into play. All batteries are affected by temperature, and should be stored at close to the ideal temp of 70 degrees.
Schumacher (yeah Don, the dragrace guy) has a great long lasting unit. We have one here at the store that was returned "defective" two years ago and it serves us everyday without fail. Overcharge protection so it can be left on the charger, inside the house, heated building untill needed.
Lynn Kirkpatrick
Lynn Kirkpatrick
Can you tell me what the model number is? I have a couple Schumacher chargers that work pretty good so far.
So this is Don Schumacher, not Michael? I'm not sure I would want Herr Schumacher to benefit from my $s.
eschneider
Lynn Kirkpatrick said:
...... When it quit holding enough charge.....
Basically these things are a battery with built-in cables. They have their own trickle chargers, which are can be terrible.
You could fashion your own, sans the pretty casing, out of a 12V motorcycle battery - might need to be a gel-cel to get the power you need - then fashion your own jumper leads, and then get a good trickle charger to maintain it. I like the "Battery Minder" (de-sulfating "pulse" type, fully automatic). Beware the "Battery Tender" - they do not de-sulfate, but confuse things by carefully claiming "anti-sufation" (i.e., avoid sulfation).
Actually, the battery minder will probably bring your current charger back to life.
Lynn Kirkpatrick
Lynn Kirkpatrick
So this is kind of getting into chemistry, a scary topic for me.
Should these things be plugged in all of the time between uses? I don't remember reading that in the instructions, but my wife can vouch for how well I do that. When I plug it in, it charges for a short time (10 minutes) then shows charged, but it doesn't have the juice to crank the MG. It is acting like a battery with a bad cell. If I plug it in for days will it de-sulfate?
Making my own is kind of a scary idea. I want it as a backup for a car we take to shows. We have a Knightrider replica and we run the electronics during the show.) Are the gel-cel batteries sealed and do you have to be careful of acid? (I know zero about them, but I'll take a look.)
Thanks
jsfbond
........After removing the PSJ-1812 from the carton,charge it for a minimum of 8 hours even if the green "Full Power" LED glows.........Recharge the PSJ-1812 after every use and every three months to full charge status to "Extend" the battery life.///These batteries do wear out after so many cycles, but should provide years of service.
TR3driver
Great Pumpkin - R.I.P
There is a lot of "it depends" in there, but all batteries lose their charge over time, so it needs to be plugged in at least occasionally to bring the battery back up. Depending on how smart the charger is, it may or may not be a good idea to leave it all the time.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If I plug it in for days will it de-sulfate?[/QUOTE]Most likely not with the integral charger. However, you might be able to save the battery by opening the case and using a "desulphator" (either commercial or home-made) on it.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:] Are the gel-cel batteries sealed and do you have to be careful of acid?[/QUOTE]Most of them are only semi-sealed. Generally they won't leak if they fall over during transport, but they need to be upright and in a vented area while charging or discharging heavily (like starting a car). (Many of them have a vent tube so the battery itself can be in a compartment but the tube has to extend outside.)
The only exception AFAIK are the "Optima" brand batteries, which are fully sealed and won't vent at all (unless they are badly mistreated). An Optima plus a really smart charger (like the BatteryMINDer mentioned above) would be my choice to build something like this.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]We have a Knightrider replica and we run the electronics during the show.)[/QUOTE]Have you considered incorporating a secondary battery instead of using an external booster? You could hide the battery somewhere within the car (trunk, under the back seat, I've even seen them stuffed into fenders), with a diode splitter to charge it from the usual alternator (so it gets automatically topped up every time you start the engine) and a solenoid to connect it directly into the car's electrical system for starting. Then your electronics can run the regular battery flat during a show, but push the button and you've got a fresh battery for starting.
Or turn it around the other way, and use the auxiliary battery to power all the electronics you want to run at the show, leaving the original battery for starting. That would probably be better, since you wouldn't need the solenoid and heavy gauge cables for the aux battery. This is a very common setup for motorhomes and such; and works quite well, IMO.
You can carry this scheme even further if you want; with two or more deep-cycle batteries in parallel to power the electronics, or even a separate high capacity alternator just to charge the aux battery pack. I had two 100AH "camping" batteries in my motorhome, because we liked to go camping away from hookups and not start the main engine for days at a time. But that's probably overkill for what you need.
TR3driver
Note that BatteryMINDer is a brand name:
https://www.batteryminders.com
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Beware the "Battery Tender" - they do not de-sulfate, but confuse things by carefully claiming "anti-sufation" (i.e., avoid sulfation).[/QUOTE]"Battery Tender" is also a trade mark/brand name, but not everyone honors it; meaning that you may find different types battery chargers called "battery tenders".
https://batterytender.com
For example, some people call this type a battery tender:
https://www.harborfreight.com/automatic-battery-float-charger-42292.html
PAUL161
What about the one Moss sells? Any comments? PJ
A Can I use a battery booster on my + ground BT7? Austin Healey 6
K TR2/3/3A Old school battery shut off switch....... Triumph 3
tahoe healey Battery Chargers vs. Maintainers Austin Healey 25
Bayless What size battery for my '67 Sprite? Spridgets 5
Sopwith_Camel battery drain Jaguar 35
Popeye General TR Battery Tray - yes or no? Triumph 11
Gatheringtree TR2/3/3A Changing out the battery liner Triumph 11
B MGB 1977 MGB Battery Box and Shifter knob MG 4
B T-Series Battery replacement mgtd MG 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
tahoe healey Battery Lifespan Austin Healey 8
EWD TR6 Battery charge loss Triumph 25
NutmegCT Upgrade your battery? Electric Upgrades of All Sizes 8
D Battery Minders Austin Healey 3
R MGB BATTERY DRAIN MG 7
D TR2/3/3A Battery Box drain Triumph 9
T TR2/3/3A Should there be a body ground strap to battery on TR3 Triumph 7
steveg Battery Cable Specs Austin Healey 33
Jim_Stevens TR2/3/3A Arcing & Sparking at the battery terminal to ground Triumph 7
GeorgeC Painting the Battery Austin Healey 0
GeorgeC OK to paint battery? Spridgets 9
D Battery connections Spridgets 0
A Wedge Won't fire without jumper from coil to battery Triumph 6
69MGC MGC Putting a 12v battery in the trunk MG 10
T How do you cover your battery in the boot? Austin Healey 5
S TR2/3/3A Need New Battery for TR3A Triumph 9
Busted knuckles TR2/3/3A Lead sled, spiral shank nails and dead battery box’s. Triumph 13
Y MGB Battery relocation ponderings and considerations [and ideas?].... MG 6
D New Battery Needed for BJ8 Austin Healey 9
HealeyRick Vented Battery Austin Healey 6
sparkydave 1500 battery cable colors Spridgets 1
G BN6 Battery location Austin Healey 7
L TR2/3/3A helmet style battery terminals Triumph 7
MGBGM1977 MGB AGM M/C battery MG 15
TRMark TR4/4A Miata Battery Triumph 6
RAC68 Battery Fuse Protection Austin Healey 101
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
wangdango BJ8 inner battery hold down? Austin Healey 4
JimTR4 TR4/4A Battery recommendation Triumph 11
3798j Fastronix Battery Compression Ends Restoration & Tools 4
M battery helmet stuck on post help Austin Healey 8
69MGC MGC WANTED: Passenger side Battery Box Bracket MG 0
NutmegCT Whacko battery[s] Restoration & Tools 7
NutmegCT battery post connectors Restoration & Tools 6
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
NutmegCT Solar battery maintainer? Restoration & Tools 9
S TR2/3/3A Replacement Battery Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S Battery - BJ8 Austin Healey 8
D Battery Tray Size Austin Healey 1
