Advise on how to re-install my transmission?
apbos
Group
My transmission is ready to install on my rebuilt 948. I will have to do this myself, with my motor on a dolly. Initial attempts have not gotten the bolt holes to line up. Difficult to do by yourself. Should I put the motor on it's nose to have gravity work with me while lining it up? Any advise?
Thanks
Paul
I've not done a 948, but the 1275's seem to slide on with no problem. Did you check for burs on the locating pin/hole.
The obvious......clutch centered?????
Kurt.
Kurt.
X2, never really had a problem before. I had one give me some trouble (can't remember which car) and the clutch wasn't lined up perfect. It still went together, just not as easy as it should. Don't force it, something isn't right. There's no reason you shouldn't be able to do it be yourself.
I used the centering tool, I will check the postitiion again. I wil check the locating pins again. My dad said to put the transmission is gear so I could line up the splines. I also put some grease in the pilot bushing (may be too much ?). We will try again tonight.
Thanks
Paul
If it won't go together the next time try this experiment-
Remove the pressure plate and clutch disk and try to mate them (engine and trans) again. If it goes together then see if the disk will slide onto the trans shaft (without the engine). If the disk DOES slide on the shaft OK then it was a centering problem.
BillM
Most of those clutch disc centering "tools" are next to worthless. Their tolerances and clearances are too great to be any better than a rough guide. The weight of the disc is sufficient to move it off center enough to cause interference. I've often done a better job just eyeballing the components. Whatever you do, DON'T try to draw the engine and transmission together using the mounting bolts. It will slip together with NO force when everything is lined up. Bob
Group
Thanks
Paul
Paul,
Lining up and bringing home any of the A-series gearboxes should be quite easily done single handed. Your mentioning having put grease in the pilot bush makes me suspicious. More than the slightest amount of grease will create a seal with an air pocket behind it that you would not be able to overcome. That's why the technique of removing and old one by filling the bore with grease actually works to drive the pilot bush out. Typically, the pilot bush is oilite, which should be soaked for 24 hours prior to installing. no grease should be necessary.
You are all on the correct track. Put a little bit to much grease in the bush and used the incorrect centering tool. I was given both of these when I had the motor at the machine shop. They said they did so little work on A series transmissions and clutches they would not need them anymore. I always "assumed" they were the same. Cleared out the grease and used the "long" centering tool and Bob's your uncle. Thanks for the help guys. I am getting closer!
If you look at my Tech page, you'll see the difference in input shafts between the smoothcase and ribcase.
https://gerardsgarage.com/Garage/Tech/TO_Bearings/tobearings.htm
This is also what you want to use the thicker cast backplate with a ribcase.
So I have a set ! Never thought there would be a difference!
An old trans input shaft works best IMHO. Years ago I picked up a set of line up tools that an E-bay seller had made up for sale. They were cast out of some sort of plastic using molds he had made up from original trans input shafts. They work quite well and the set covers all common British cars. Too bad he didn't keep making them.
Kurt.
H TR4/4A Advise asked for front repair Triumph 1
H TR4/4A Advise asked on TR 4 a frame collision/issue Triumph 20
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
P Classic Mini advise British Motor Corp 1
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
Jim_Gruber Speedi Sleeve required for this application - Need advise! Spridgets 12
T Newbie Bugeye Sprite owner engine advise needed Spridgets 5
JFeher TR2/3/3A Rebuilding A type OD I Need advise / measurements Triumph 14
NullReturned Full Service Advise for '68 Sprite MKIV Spridgets 7
jlaird Now I need advise Spridgets 16
jlaird Advise and guidance pls Spridgets 22
G Top cleaner advise sought! Triumph 1
M Advise on Bonnet removal Spridgets 25
S Please advise! MG 2
1 MGB Now that I have my 75 MGB running, need advise MG 2
W Advise and counsel please Spridgets 9
Randy Harris Roll up window replacement - advise needed Austin Healey 4
M Need advise on new Exhaust Valves Triumph 12
Steve_S TR6 TR-6 Advise - QUICK! Triumph 18
T need advise on inspecting a sprite. Austin Healey 1
T need advise on inspecting a sprite. Austin Healey 0
jlaird I took your advise Spridgets 4
Steve_S Advise on Multipurpose Lathe Please! Restoration & Tools 9
jlaird I need a bit of advise and guidance Spridgets 11
hondo402000 TR6 insurance advise for TR6 Triumph 15
jlaird BMW question/advise Spridgets 11
T wiring advise Triumph 5
jlaird Look at this, advise pls Spridgets 7
SCguy Waxoyl question/advise Triumph 13
T More advise needed. This time the axle shaft..... Triumph 0
911cop Evil temptation lurks. Pls advise. Austin Healey 6
P New user of this forum seeks advise Austin Healey 0
R TR2/3/3A Need advise of TR3 engine expert....[long] Triumph 5
SherpaPilot TR6 New Ammeter Install Question Triumph 5
D TR4/4A TR4A top install details Triumph 12
S TR6 Windshield Install Triumph 11
C TR4/4A Install after jet gland replacement SU H6 in TR4 Triumph 9
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
