MGB 77 MGB Alternator Wiring
kyreb1862
The other day I made a post about my alternator not behaving as I thought it should. I decided to pull the alternator and have it checked. The alternator shop informed me that they couldn't find anything wrong with the alternator and in the process of removing the alternator I may have discovered the answer to my problem. I only have (2) wires connected to my alternator and both of them are brown. The yellow/brown wire is missing. So far I haven't been able to locate it in the wiring harness. Is there any chance that the factory could have used another color? The only unused wire I have found so far seems to be black. If any of you have a good picture of the wiring at the back of your 16acr alternator please post it so I can see where the yellow/brown wire is supposed to be in the harness.
Regards John
Your alternator will not work without the "yellow" wire on, which is you ignition warning light. If the alternator doesn't sense a load on that wire when you turn the key it will not work. Learned that the hard way when I used a LED in the ignition warning circuit which didn't draw enough current to switch the internal relay on.
See if you can follow that wire or find out what colour leaves the dash light
Thanks for the help DJTHom. I went through the wiring yesterday and found a little DPO trick I would have never thought of. My DPO had cut the terminal off the yellow/brown wire and hooked it into the unused wire that led to the former seatbelt inter lock system. I cut this loose and wired it back into the alternator and now it works as it should.
Regards John
That's almost one for the joke book.
WTF?!?!
Guess that's a front runner for the role of "the emitomy of a DPO"!
D MGB mgb 77 alternator wiring. MG 2
G MGB Alternator wiring "71 MGB MG 4
drooartz General MG Alternator link - adjusting bracket length on MGB? MG 8
aeronca65t MGB MGB 5 wire to 3 wire alternator MG 2
kyreb1862 MGB Alternator Problem 77 MGB MG 0
Carlbanan56 MGB MGB valve seals MG 1
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
ab-1970mgb Wanted 1970 MGB - Emissions Parts MG Classifieds 4
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
