2nd set of detail questions: 1963 BJ7
Fairview
Thank you all for answering my first set of questions. I have just a few more, and I promise to quit bugging you.
1) Is there a piece of trunk liner missing on my car? Or is that rear panel supposed to be uncovered?
2) Is the metal top frame the right color?
3) All the small bits in my engine compartment are bare metal and getting surface rust (e.g. screws, brackets, accelerator linkage). Should these be painted, and if so, color?
4) Somebody put 8mm gray plug wires on this 3000. What are the proper plug wires and spark plug connectors?
I think that is it for now. Just want to say thanks for bearing with me. I guess I could have found a book for this info, but it is more fun, and probably more accurate, to ask you all.
If you see anything else in the photos that I should tend to, please sing out, it won't hurt my feelings. I just want this 3000 to be as authentic as it can be.
Best regards, Jeff
richberman
Jeff,
In addition to all of the great answers here I would suggest that you purchase the concours guidelines. They are not very expensive and chock full of the minute details. I read mine over and over again and keep finding nuances.
Here's the information for ordering as of 2010:
2010 Concours Registry
Guidelines Order Form (v. January 2010)
Complete form and submit with payment made payable to “Mike Osipik-Treasurer
AHCR” (US funds Money Order, Personal Check or equivalent. Do not send cash) to:
Mike Osipik
C/O Austin Healey Concours Registry
39 East 55th Terrace
Kansas City, MO 64113 USA
<span style="color: #000099">mikeosipik@earthlink.net</span>
816-333-2506
Please print legibly.
Address: _______________________________________________________________
City, State, Zip Code: _____________________________________________________
Country (if other than US) _____________________________
Email Address: _____________________ Phone: _____________________________
Please note your car(s) description: Year__________
Model—BN1__ S__ BN2__ M__ BN4__ BN6__ BN7MK1__ BT7MK1__
BN7MK2__ BT7MK2__ BJ7__ BJ8 Phase 1__ BJ8 Phase 2__ Other____________
Sprite—MK1___ MK2___ MK3___ MK4____ Other________________________
The Austin Healey Concours Registry Guidelines and Judging Forms are Copyrighted documents provided
for the exclusive use of individuals purchasing the documents through the Austin Healey Concours Registry.
All guidelines will be distributed via CD with PDF and MSWord file formats. If you do not have Acrobat
Reader on your computer instructions will be provided with your order or you can go to:
https://get.adobe.com/reader/ for a free down load copy. Purchaser is allowed to print one set for their library
and one set for their work shop. Files are not to be sold, distributed, transmitted via internet, altered or used
in any other manner than intended by the Austin Healey Concours Registry.
(____) Big Healey Guidelines CD w/color photos
AND/OR
(____) Sprite Guidelines CD (Last update 2001) - no photos
Price includes shipping via US Priority Mail-
US Address: $20 USD
Canada and Mexico: $25 USD
All other countries: $27 USD
Ordering both Big Healey and Sprite Guidelines? Add CD cost of $15 USD and ship
with your current order (no additional postage cost)
Description- Each CD includes files for the following:
Policies and Procedures, Judging Guidelines, Photos (Big Healey), Score Sheets
Brinkerhoff
Jeff, most all of the hardware that is rusting underhood should be white zinc plated to be authentic. You can buy a kit to do this from Caswell Plating (find on internet). You need to buy the Anderson/Moment book on Healeys! The engine was painted as a complete assembley when new so most of the pieces directly attached to it were also green. There is a filler piece missing in your boot liner , it tucks behind the support for the boot striker. The hood frame looks fine. You're missing bonnet buffer pads and weatherstrip which will support your bonnet properly and keep it from chipping the shroud paint. It looks like a pretty decent car and I'm sure nobody here feels bugged ! The better you know your car the better service it will give you. Kevin
Healey_Z
Jeff, That is what car forums are all about! You take excellent pictures an I enjoy seeing the details. The one item that jumps out to me as being out of place is the braided fuel line.
re: #4) The correct plug wires are 7mm stranded copper wire core with a right-angle plastic caps with 'Lucas' embossing on the end (Moss Motors and other suppliers have them). If you have an original-style distributor cap with the 'puncture-style' terminals and modern, spiral-wound carbon-core plug wires you will likely experience ignition problems sooner or later (an occasional miss on acceleration may be the first symptom).
There should also be rubber O-rings corralling the #1-#2 and #5-#6 plug wires together.
Brinkerhoff
The braided fuel lines look to be as correct as you'll find, even the clamps look right. The fuel lines would each have had yellow ID bands on them, "Smiths Petroflex" if I remember. Looking the the underhood picture and blowing it up I can see a lot of effort to get it close. Leave it to the British to put a Lucas electrical horn directly underneath an SU carb. If I'm not mistaken this car is early enough that it still uses the 100-6 wiring diagragm in the shop manual.
Rob Glasgow
I don't see the Cooper decals on the air filters. Maybe they weren't added to the BJ7 like they were on my BT7.
AH3000MkIII
Lovely car Jeff, how authentic your car is can't necessarily be answered looking at photos, it all depends on what level of detail you want to go to. You could start down the road of making sure that all of the Lucas dated components have the correct date codes on them to match the build of your car, etc... One thing I notice that's not 100% right is the battery isolating switch, the correct original switch has a shorter knob, whereas all later replacements are longer.
AUSMHLY
Nice photos Jeff.
I noticed the copper water pipe is not painted. It should be the same color green as the engine. As mentioned, some of the parts on the engine were painted engine green while on the engine, just like the short rubber hose, to the left of the T tube at the back of the valve cover, and the J shaped rubber tube at the bottom of that pipe.
For safety, put an inline fuse close to the license plate lamp.
BigGreen
For bare metal or the zinc plated look for Race Glaze Jet laq non-paint laquer
Its a sort of clear coat but heat resistant
I have used it on the copper pump of my high presure cleaner, works great
Hans
F
Fairview
Thanks for all this good information. It is more than I could have expected and makes taking care of the details so much easier.
Could you help me with a question about my posts? If I click on any of the photos I've put on, it will take me to my Smugmug photos, and from there I can go back into my other files (that have some of my other projects/junk, etc.). I don't know if it is just my computer, since it is my account, or if it works that way for everybody?
Thanks, Jeff
F
Fairview
HealeyRick said:
Jeff,
I can view anything in the "Milepost 105" account. Here's what displays: Milepost105 > Cars > 1963 Austin Healey 3000 Mk II BTW, you're BJ7 is most impressive!
Rick, Thank you very much for checking for me- that is good to know.
Jeff
British_Recovery said:
Hi all, Boot lid bumpers (small, round,black rubber pads) are missing from the three holes along the shroud edge. Nice car, Bob
Good catch. There should be one (or more, can't remember) along the top of the windshield frame as well (might even be the same part number).
TimK
Brinkerhoff mentioned the 3 bonnet (hood) buffers and carburetor weatherstrip (to keep water out of the carbs. Here is a picture of the setup on my BN7. Yes, your car is top notch.
Tim, I think you are missing one on the left side on your picture that is near the front. The one by the carbs should have a fin to it. At least that is how it is on the BJ8s
AUSMHLY
On the BJ8 there are 3 rubber buffers on the left, and one on the right bottom corner, plus the long rubber strip with a fin (2nd photo show the fin), on the right to protect the carbs.
Cheers,
Roger
T General TR Another trans popping out of 2nd Triumph 14
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
TR3driver TR4/4A New document available - TR4A Spare Parts Catalogue 2nd edition Triumph 5
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
doc50 TR2/3/3A Pops out of 2nd gear Triumph 7
Csarneson Source for BN4 2nd Gear Austin Healey 8
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
H 1st and 2nd gear problems Austin Healey 5
glemon TR5/TR250 Tranny Won't go into 2nd TR250 Triumph 13
B 2nd gear blocking ring failure BJ7 Austin Healey 5
Coyote1 2nd Gear OD or Not Triumph 19
dougie Cali Healey Owners - Sonoma June 2nd -5th Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
R lost 1st and 2nd! Spridgets 10
regularman 2nd condenser in a short time. Spridgets 13
B Last Green Valley Rallye, May 2nd Jaguar 5
H jumping out of 2nd gear Austin Healey 3
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
theleisure 2nd Gear, Please Don't Go Away! Spridgets 8
J Downshifting from 3rd to 2nd Austin Healey 7
T 2nd day of Amos Triumph 24
D no syncro 2nd advice MG 13
A Gearbox rebuild - popping out of 2nd advice? Video Austin Healey 18
Jayrz Poor Shifting 2nd gear MG 5
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
Brosky 2nd Valley of Sin run SE MA & RI Triumph 0
fmichaels 2nd tranny rebuild inprog Spridgets 11
T Crypt Clutch 2nd Look-see Triumph 203
AUSMHLY 2nd gear Austin Healey 5
aeronca65t OT: Mother Ship is out of here! 2nd Diff broke! Spridgets 0
Shealey OT: Mother Ship is out of here! 2nd Diff broke! Other Cars 10
G 1st prize,3 days in July in TX, 2nd prize,5 days Triumph 9
zimmy wanted- 2nd gear for 1275 Spridgets 9
zimmy jollyroger -2nd gear for 1275 Spridgets 4
