2nd gear should I file it? Do gears have a hard coating?
AUSMHLY
Just received a 2nd gear, one tooth is chipped. I showed this to the mechanic and he said you might want to file the cut out edge of the chip smooth. Your thoughts?
When looking at one of my other gears he said it looks like the hard coating is coming off, and that it will wear quicker because of that. I'll assume he has trained eyes, for I could not see any coating. Is what he says true? (I'm attaching photos of my newly acquired 2nd gear. It looks original. I don't see any "hard coating").
The welded rebuilt laygears seem to have a dark coating. (photo attached) What is that coating?
Next to that laygear, you'll see the 2nd gear I bought and showing close up photos. Your thoughts about the chip in the tooth? File the edge of that chip or not?
Thanks guys :smile:
red57
Gears are heat treated and very hard, I doubt if a file will touch it. You might try a small whetstone or Arkansas stone and see if you can smooth the edges a bit and make sure there aren't any burrs. BTW, this gear sure looks to be a lot better shape than the other one you showed.
The dark coating on the repaired laygear may be from nitriding or tuftriding which is are heat treating processes that add a high carbon content to the surface of the part - may be that is what he was referring to? I'd suggest asking him to explain what he meant.
vette
I’m not an expert on gears or metallurgy but I definitely would file that gear if it were mine. Just from what I read about sharp edges and stress risers I would do it. Look at it this way, when another gear comes into mesh with this gear it’s going to have a rough merger with it. That edge is going to get worn down in the least or possibly chip some more in the process possibly or causing a crack. Maybe damaging the other gears. The chipped metal is already gone. Smoothing that edge to make the mesh easier isn’t going to take that much off. Just enough to smooth the mesh.
pkmh
I can't say enough one way or the other if smoothing out chipped gears helps as in this case, but assuming so, then try "Dremel" it. Having the right grinding wheel at high velocity never stopped me from cutting or smoothing out virtual anything.
Madflyer
As gears go they are very hard and heat treated, not the body of the whole shaft. The point being gear surface does the work and the body is at the casting strength. As with your gears chip that what hardening does this can happen by just dropping a gear. If you use a grinder to dress the chip DO NOT LET IT GET HOT. It is only one tooth so loading is little in the life of the gear. When the face of a gear is gone it eats up quickly, the hardening is not very deep.
Madflyer
What is with the welding on your gear? This photo shows a gear made into an award. I have never seen gears welded. The temper is gone and unless reheat treated it would be junk. Anybody have any ideas?
AUSMHLY
AUSMHLY
I did not buy the welded laygear in that photo, only the 2nd gear.
It's my understanding that once the factory laygears weren't available, vendors began selling reconditioned laygears where the 1st gear section was cut off and a replacement was welded. Vendors sell these, wanting yours in return. It seems that new reproduction one piece laygears are being made and sold by some vendors now. Is your award a 22B141 laygear, NOS? I need it :smile:
John Turney
The "Big Teeth" on that gear are in constant mesh with the matching lay gear, so as long as there is nothing sticking up, there is no reason to file that tooth. When shifting, the "little teeth" come into play.
The sliding hub, with the help of the syncro/balk rings, engage those little teeth. The little teeth need to have sharp ends on them. A couple show wear, but as long as almost all are sharp, it should work fine.
It looks like the friction surface on the cone-shaped area looks to be in good shape to make the balk ring work properly. When you put the balk ring on the cone area and push it toward the teeth, the gap between the balk ring teeth and 2nd gear little teeth should be about 0.025".
The dark coating is the result of heat treating.
All you have to do is win the award. :devilish:
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
tr6nitjulius General Tech Visual/audible Fix no 1st/2nd gear Triumph 0
tr6nitjulius General TR Final solution to no 1st/2nd gear issues Triumph 2
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
K TR2/3/3A Gear shift pops out of 2nd gear sometimes? Triumph 5
doc50 TR2/3/3A Pops out of 2nd gear Triumph 7
Csarneson Source for BN4 2nd Gear Austin Healey 8
R bj7 hard shifting into 1st & 2nd gear Austin Healey 6
H 1st and 2nd gear problems Austin Healey 5
B 2nd gear blocking ring failure BJ7 Austin Healey 5
Coyote1 2nd Gear OD or Not Triumph 19
H jumping out of 2nd gear Austin Healey 3
theleisure 2nd Gear, Please Don't Go Away! Spridgets 8
Jayrz Poor Shifting 2nd gear MG 5
71tr TR6 Moss replacement 2nd gear bush - TR6 Triumph 0
AUSMHLY 2nd gear Austin Healey 5
zimmy wanted- 2nd gear for 1275 Spridgets 9
zimmy jollyroger -2nd gear for 1275 Spridgets 4
zimmy 2nd gear Spridgets 6
RobSelina 2nd gear whine [1500 midget] Spridgets 8
T General TR Another trans popping out of 2nd Triumph 14
tr6nitjulius TR6 TR6 No 1st/2nd problem/solution Triumph 4
M T-Series MG TD 1st/2nd sliding hub end play MG 1
W TR6 Seat diaphragm failure on 2nd seat! Triumph 8
W Find gearbox rebuild [2nd synch shot] South. California Jaguar 1
AUSMHLY Shifting into 2nd, problem because of the Flywheel? Austin Healey 21
KVH General Tech Grinding Gears in Shift From 1st to 2nd Triumph 13
DerekJ Jack Rawles Racing at Zandvoort. From 6th to 2nd. Austin Healey 4
TR3driver TR4/4A New document available - TR4A Spare Parts Catalogue 2nd edition Triumph 5
Lotus Club SoCal 2nd Saturday Breakfast – Lotus Club of SoCal Activities Planning Meetings Lotus 0
M TR2/3/3A 2nd commission [vin] number??? Help. Triumph 12
glemon TR5/TR250 Tranny Won't go into 2nd TR250 Triumph 13
F 2nd set of detail questions: 1963 BJ7 Austin Healey 21
dougie Cali Healey Owners - Sonoma June 2nd -5th Austin Healey 9
Jim_Gruber 2nd Grease Fitting on Fulcrum Pin Spridgets 5
bigjones TR2/3/3A TR3/4 clutch adjustment and shifting into 2nd Triumph 5
EricG Sunbeam Gathering- Oct. 2nd, Columbia,SC Sunbeam (Rootes) 0
R lost 1st and 2nd! Spridgets 10
regularman 2nd condenser in a short time. Spridgets 13
B Last Green Valley Rallye, May 2nd Jaguar 5
AUSMHLY Youtube...Finished my 2nd video....007 Healey Austin Healey 16
J Downshifting from 3rd to 2nd Austin Healey 7
T 2nd day of Amos Triumph 24
D no syncro 2nd advice MG 13
A Gearbox rebuild - popping out of 2nd advice? Video Austin Healey 18
Mg_Bizzle Considering 2nd hand engine, advice needed MG 26
Brosky 2nd Valley of Sin run SE MA & RI Triumph 0
fmichaels 2nd tranny rebuild inprog Spridgets 11
T Crypt Clutch 2nd Look-see Triumph 203
aeronca65t OT: Mother Ship is out of here! 2nd Diff broke! Spridgets 0
