TR2/3/3A TR3 starter disassembly rebuild early M428G bomb
geewiz
TR3 starter disassembly rebuild early M428G bomb. Can someone explain what is happening in this photo? Acc to Triumph repair manual this should be a nut screwed on and secured by a pin through the armature shaft.
Is this a nut? Because it refuses to budge even in a vice.
Where is the pin?
How to disassemble from here?
Thanks
sp53
Usually when you get the almost impossible to remove inset snap ring out everything slides off. I have read about that screw, but new have seen one. From what I have read the screw was only used early and not for very long. To me it looks like the piece on the shaft is broken, chiped, and froze or it would slide off. If you need some pics I will dig through my old starters and take one either today or tomorrow.
steve
CJD
Yes, it is a nut. It is heavily staked, and I think I can see the head of the pin in the groove, at the top of the first picture. Based on the amount of staking, and the fact you must drill out the pin...I would make sure you have a replacement before I went any farther. Removal will likely ruin the nut.
mctriumph
If you are working on a early" bull nose" starter you have left the path of Reason and are now headed towards DESPAIR !! These
units have an Achilles heal that is age related, and has no replacement parts. Chance of failure 99.9% first 30 days.
Been there ,done that...
Mad dog
Jim_Stevens
PM me if you’d like to shift to a gear-reduction starter. I have an extra to sell.
TRopic6
Where is the pin?
Thanks
Hi G-wiz, A while back I tried to use a worn-out bomb starter + a loaded armature to make 1 for a spare - didn't happen because there weren't enough good parts. One armature was out because the shaft collar that keeps the inner snap ring in place was worn almost to the point of not able to retain the ring. You can see how thin the remainder is, and the pinion was very loose on the shaft.
Someone may have resorted to desperate measures to beef up that area on yours. If it is staked to the shaft like Steve says, best to leave it alone. But there should be a return spring in there somewhere.
Jeff
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
tinman58 General Tech TR3 Starter Triumph 11
N TR2/3/3A TR3 Starter rebuild Triumph 3
M TR2/3/3A TR3 starter part need Triumph 3
J TR2/3/3A ? on removing tr3 starter? Triumph 16
af3683 TR2/3/3A Late TR3 Starter Triumph 3
NutmegCT TR2/3/3A 1959 TR3 - dying starter? Triumph 4
af3683 TR2/3/3A TR3 Starter Lubrication Triumph 5
af3683 TR2/3/3A Painting Original Lucas TR3 Starter Triumph 3
Kleykamp TR2/3/3A TR3 Starter nose broke off, ring gear,lots of ??? Triumph 6
D TR2/3/3A Removing TR3 'starter' bolt Triumph 3
K TR2/3/3A TR3 starter dog bolt torque value? Triumph 1
K TR2/3/3A TR3 starter dog bolt removal.... Triumph 9
W TR2/3/3A TR3 STARTER SWITCH ASSEMBLY PROBLEM Triumph 18
R TR2/3/3A TR3 Starter removal Triumph 6
J TR2/3/3A Aftermarket starter for TR3 question Triumph 8
tinman58 TR2/3/3A Hi torque starter TR3 Triumph 2
H TR2/3/3A TR3- Who offers a good alternator kit + starter Triumph 28
M TR2/3/3A 1956 TR3 starter length handle Triumph 2
S TR2/3/3A tr3 solenoid to the starter Triumph 6
M TR2/3/3A Rebuild early bomb style starter TR3 Triumph 3
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
M TR2/3/3A TR3 Starter sound Triumph 7
A TR2/3/3A TR3 starter handle length Triumph 8
prb51 TR2/3/3A TR3 Starter issues Triumph 17
M TR2/3/3A TR3 Gear Reduction Starter Triumph 5
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
Moseso TR2/3/3A TR3 Starter/flywheel/tranny case Triumph 5
gsalt57tr3 TR2/3/3A TR3 starter removal Triumph 6
martx-5 TR2/3/3A Headers and Starter on TR3 Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
