Windscreen/windshield rubber
2wrench
Nearing reinstall of windscreen (waiting on dash parts)
and heeding advice from the forum, paranoid about
installing windscreen with rubber gasket at the base of
the windscreen frame.
Old rubber seems a bit wider to fit well along the bottom
edge of the windscreen. Replacement part seems
narrower than the old. Looks as if what needs be done is
to lift the front outter edge of the rubber (edge closest to the opening edge of the bonnett) with a wide plastic
putty knife. This looks as if it will flare that edge
and could be okay once the windshield is tightened down.
Could it be that I received the wrong bottom gasket, like
an earlier year TR6? Mine is a 1974.
Plan on seeing a pro to install; but if I provide the
wrong part and she leaks, I'll pay in both time; labor;
materials and the agony of being so close to driving, yet
so far away.
I like to listen first, then jump (took years to get there.)
2wrench
G
The gasket will spread out nicely once you torque that frame down. Just go slow and take your time.
roofman
He is right, I thought mine was too narrow also but ended up exactly the right width when pressed down.
2wrench
2wrench
Gentlemen: You were right. While the rubber looked
rather small, it did stretch into place and went on as
it should.
Thank you for your help.
2wrench Windscreen/windshield rubber Triumph 6
6 TR2/3/3A TR3 windscreen/windshield glass Triumph 5
jjbunn MGB-GT MGB Gt Windscreen Windshield Refit MG 5
W Windshield / Windscreen Wiper Motor Austin Healey 1
B Windscreen Motor Repair Restoration & Tools 6
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
RCarr Windscreen Glass Options Austin Healey 2
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
W Tudor windscreen washer bottles Spridgets 0
Popeye TR4/4A Tonneau snaps by windscreen Triumph 2
I Replacing Windscreen Wiper Wheel Boxes Austin Healey 0
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
K TR2/3/3A I saw a 59 TR3 today with an aluminium windscreen! Triumph 5
A MGB MGB 1974 windscreen centre rod replacement MG 5
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
71TR6 TR2/3/3A TR3 windscreen frame corner bracket screw thread Triumph 9
LAW75 Repairing Windscreen Scratches Austin Healey 10
Healey Nut BT7 Windscreen Pillars Austin Healey 4
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
G windscreen problem Spridgets 1
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
M Windscreen Wipers Parking Spridgets 4
M General MG Magnette windscreen washers MG 1
B TR2/3/3A Windscreen galss replacement Triumph 5
R Windscreen Glass Austin Healey 6
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
J Wanted TR3 Windscreen guide plates Triumph Classifieds 7
R BJ8 Windscreen Change Austin Healey 2
C Folding Windscreen Austin Healey 20
P For Sale tr6 windscreen Triumph Classifieds 0
4tecdog Windscreen rail to hood seal Austin Healey 11
bugedd Measurement of windscreen glass Spridgets 7
K TR2/3/3A Windscreen seal Triumph 16
4tecdog Frogeye Windscreen Spridgets 3
Jim_Gruber Free Spridget Windscreen available - Dayton OH Spridgets 3
K Windscreen Washer Question Austin Healey 26
M TR4/4A Windscreen capping Triumph 0
G TR4/4A Inside Windscreen Capping Triumph 6
B Windscreen washer pump upgrade Austin Healey 10
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
CJD TR2/3/3A Windscreen Tenax Triumph 22
B TR6 Windscreen removal advice Triumph 10
NutmegCT T-Series windscreen glass? MG 8
TRMark TR4/4A Installing a new windscreen Triumph 9
Bugeyze BN4 Windscreen Shims? Austin Healey 13
bugedd Windscreen glass question Spridgets 0
TRMark TR4/4A Top Tint Windscreen Triumph 0
bugedd Windscreen and top fitment issue Spridgets 16
