USB and Auxiliary Power Connections
twas_brillig
There's a thread entitled 'USB' over on the Spridget side that would be worth reading for anyone who wants to add a 12 volt plug-in of some sort.
I won't attempt to summarize the discussion there, but will add that the approach we took years ago was to remove the passenger side grab handle and wooden backing piece behind the dash, replaced the wood with a larger piece, and mounted a cigarette lighter connection onto the wood. We use it when driving to power a GPS unit, and will swap out plug-ins/adaptors as required to charge phones etc. It's completely hidden and out of the way - also a bit awkward. Doing it today, I'd probably take the same approach but probably add a second purpose built USB connector only and maybe try for a more solidly built 'power take-off' (I think that's the modern phrase). Can't remember if I put a fuse in (just in case), but hope that I did. Doug
gonzo
Good idea. I use the Cig "Lighter" and plug adaptor(s) powered now from on a axillary fuse block. 12V power, USB, USBc, etc., etc. functions.
I put a cig lighter under the glove box of my BJ8 to plug my GPS and it has a port for the USB to charge my cell phone. Very cheap and very easy to wire.
Healey Nut
Easy add , voltmeter with dual USB outlets , Amazon .
Jkirchner
Bronze
I made a panel to hide the stereo wires on the passenger side of the console and installed a lighter socket and a usb port that plugs into my stereo.
Todd78d USB Spridgets 8
J USB/iPod/SD/AUX audio adapter British Motor Corp 1
NutmegCT T-Series Auxiliary reservoir for rear dampers MG 1
P Auxiliary fuel pump Triumph 16
pjsmetana Auxiliary Oil Feed to Rockershaft on 1500 engine Triumph 4
T Auxiliary oil line --- revisited. Triumph 7
77_MG_Midget Auxiliary Radiator Spridgets 14
Sopwith_Camel MGA MGA no power MG 4
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
