TR2/3/3A Uprated pulley kit with uprated 6 blade water pump problems.
aaronf30
I have a triumph tr3a and I just bought an uprated "gold classic" 6 blade water pump from moss along with the 3/8 pulley kit. I also bought a woodruff key, but it doesn't seem to fit in the water pump. Anyone else have this problem? is there a different size I should buy? It definitely looks smaller than the old slot.
Can you tell how much too big it is?
Sometimes a few strokes of a fine file are needed to get a good fit. Lay the file on the bench and rub the key back and forth on the file. Keep checking the fit.
Also worth checking that there are no burrs in the key way.
David
I think the problem might be mixed up dimensions surrounding the key and keyways. I had a problem last year with a key and pump that were 5mm (maybe 3 mm) and a pulley with the oem 1/8.
I had the same problem and did what David said. Took a while to do. Also I'll be curious if you have a different problem. Others on the forum expressed this same symptom with the new up rated pump installed and that is a creaking noise at start up. Goes away after the engine warms up. I had all kinds of thoughts going through my head till I heard it was nothing to worry about.
Don't use the narrow key with the 1/8 cast iron pulley. There is no taper on the shaft and the little ridge on the shaft will not give you enough pinch against the pulley nut to keep the heavy cast iron pulley from wanting to turn ever so slightly on the shaft. The ever so slight wallow this will put in the pulley groove will keep you from removing the pulley next time.
Ah sorry I forget I have to check notify to get emails when I get responses. I figure no one had responded. Turns out a woodruff key was missing in the box, moss sent me a new one.
T TR2/3/3A Moss uprated water pump Triumph 6
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
K TR2/3/3A Yellow wire uprated condensor Triumph 1
steveg Reflectors to Taillights - uprated Austin Healey 9
hondo402000 New uprated spindles and Wildwood calipers Triumph 11
nissanite TR4/4A Uprated TR-4 oil pump or.... Triumph 13
RedTR3 TR2/3/3A TR3 Uprated Water Pump? Triumph 11
C Uprated springs or stock? Triumph 2
Westfield_XI Uprated axles for wire wheel hubs/Frontline Spridg Spridgets 6
G Has anyone uprated the rear axles to CV joints? Triumph 47
SCguy Uprated differential bushings??? Triumph 4
PAUL161 T-Series Dynamic Balance Pulley ??? MG 0
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
K TR2/3/3A Replacing water pump pulley.....memory refresh. Triumph 7
T MG Midget 1500 crank shaft pulley Spridgets 0
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
K TR2/3/3A Timing marks on pulley? Triumph 10
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
BN6_2197 BN6 Pulley Diameter Austin Healey 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
M TR6 Dowel Pins, Pulley Adaptor, Revotec Electric Fan Kit Triumph 1
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
Got_All_4 TR6 Engine pulley dampener 69 vs 70 also new or rebuilt Triumph 1
steveg BJ8 Alternator - small belt in large pulley Austin Healey 4
Rhodyspit75 Generator pulley diameter Spridgets 2
Jim_Gruber 1275 Damper Pulley Needed Spridgets 16
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
M 948 Pulley Nut Size Spridgets 1
Michael Oritt Pulley Problem Austin Healey 18
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
SASSAMON TR2/3/3A WTB Pulley and Fan for TRactor Dynamo Triumph 3
F Tightening the idler pulley bolt on a 1098 Spridgets 2
MadMarx Wedge Pulley Triumph 8
L Trouble refitting pulley to new water pump Spridgets 9
T Replacing the crank pulley/damper Austin Healey 4
R GT6 Mk1 Pulley weighting marks Triumph 6
mgedit TR2/3/3A Removal of Fan Extension and Pulley Triumph 20
S TR4/4A TR4A Water pump pulley loose Triumph 10
Jake Correct generator pulley and fan? Pics needed Austin Healey 5
Lin Pulley and belt configuration for air conditioning Austin Healey 2
M Crank Pulley Removal Austin Healey 12
J General TR Narrow Belt crank pulley Triumph 0
croz TR2/3/3A Harmonic Balancer - narrow belt pulley Triumph 12
S TR2/3/3A torque of the large pulley bolt Triumph 4
