Twin cam crankcase pressure low, VC pressure high
eschneider
Got a weird one.
Customer is finishing the cosmetic resto of a Lotus-powered Morgan (recently purchased, basically an "unknown" engine). After we re-gasketed and re-sealed and painted the engine, it is now spewing oil.
The oil was 3-4 quarts overfilled. Fixed that, but now there is very little pressure coming from the draft tube (vent from the right rear of the cylinder head), and very high pressure when the oil filler cap is removed.
we know the engine has loose rings (consensus is that this is the result of a race-spec engine rebuild from the 80's) - but this should have caused high crankcase pressures, and we have the reverse problem.
the car does smoke heavily when started. <edit> Loose valve guides wouldn't be exposed to combustion pressure, though - the valves are closed at that point. I don't think it's a cracked head or head gasket - compression and leakdown were low but equal on all cylinders.
why would there be such a differnce between crankcase and valve cover pressure? Aren't the two essentially the same given that the timing chain passage connects the top and bottom end of the motor?
There is also a profuse amount of oil under the valve cover with then engine running - is that normal?
edit - I did check for obstructions in the crank vent from the fuel pump cavity to the outlet at the head - compressed air blew though without apparent restriction.
Platinum
The easy stuff first... There *should* be a lot of oil in the troughs. The cam and "buckets" ride in it. That's normal.
The crankcase pressure is surely the rings, the oil smoke on startup is oil weeping down past the guides after it has been shut down, sitting on (likely) the exhaust valve heads. Likely what killed the rings!
Is this a Weber head or a Stromberg?
eschneider
eschneider
OK. What about a pressurized filler cap?
I have LOW crankcrase pressure - I can't feel any pressure at all coming out of the breather tube. Shouldn't loose rings be HIGH?
Weber 45 DCOE's. This motor was supposedly "built to race spec" in the 80's. Customer is confident the loose rings are "race spec" - I'm not as convinced.
coldplugs
Platinum
eschneider said:
...Fixed that, but now there is very little pressure coming from the draft tube (vent from the right rear of the cylinder head), and very high pressure when the oil filler cap is removed.
I'm working from a not always reliable memory here but the only "tube" I remember at the right rear of the head is the rubber tube that serves to drain the oil from the head back into the crankcase. This drain was just about adequate when everything was working well and they're easy to mess up when the head is installed. I don't remember any vent in that location, at least with the stock setup.
Platinum
There's a vent there, it runs to the air box, John. :wink:
<span style="font-style: italic">
EDIT: Shoulda said: "on standard engines"... An 8"~9" steel tube, mild kink about 2" from one end, shouldered on both ends to allow rubber seals to be smushed into place when the back side of the airbox is bolter to the carbs. </span>
LotusPosition
Many hipo TC's also employ an additional breather on the front face of the cam cover.
I have this on mine, it certainly reduces crankcase pressure/ oil leaks.
eschneider
eschneider
After consulting with Doc Entropy, I decided the pressure in the valve cover was "pulses" rather than pressure. To test the idea, I put a rubber glove over the oil filter cap - it "fluttered" more than "blew up"
here's a quick video, just for giggles. Just playing with the camera, really.
https://s62.photobucket.com/albums/h110/schne92650/?action=view&current=doorleyvent.mp4
So the final thought is:
1) the oil leak was primarily caused by overfilling
2) the very strong pulses in the valve cover - dunno if that's normal, and it seems like it would stress the valve cover gasket.
3) I'm still concerned there is NOTHING coming from the crank vent tube, but it might make sense that the pulses are baffled/muffled by the chamber in the head.
Even if it's 5 years from now, if anyone reading this has a similar experience or further insight, I'd love to know.
edit: after we witnessed oil bubbling around the exhaust ports (through the new gasket) the customer is now resolved that the motor needs to be "refreshed" in the near future. Some better photos of the front vent would help - sounds like this is an improvement that should be added when the motor is apart.
Platinum
It gets th' pressure from crankcase to bottle simply for settling.
LP's mill is a result of years of experience fettin' with 'em. The photo of the front vent above is what makes for no backpressure or crankcase pressure.
BTW: the vented cam cover fitting can be either home-made or acquired thru Dave Bean... Go for doin' it yourself, Eric. It was well documented ~someplace~ I can't recall just now (HELP me MB). Fairly well accepted in twink circles as a good solution.
Thanks for the pix, LP.... And dont' be such a stranger here!!!!
:laugh:
Grantura_MKI
Was just wondering as the oil filler seems to be blocked off in the picture, hense the need for another vent source? Excellent looking motor!
LotusPosition
Thanks.
It is actually an aftermarket oil cap setup. A sleeve with internal threads is epoxied inside the oil filler opening. A screw in cap with o ring eliminates the leaking problems that go with the stock cap. Looks better too. :smile:
Roger
Bronze
The vented cam cover referred to by Doc above, was documented as a cure for oil leaks in TC Europas.
Read it Here.
Platinum
Lotus West and L.O.U. carried that as well.
Funny/interesting the T/C Europa guys show the alternator PULLEY on the exhaust cam and site ITs seal as a leak point. :wink:
Roger
Bronze
The document in the link I sent shows the alternator pulley on the inlet cam, where it should be.
Here's my engine . You can see the breather pipe coming from the front of the cam box.
Platinum
I wuz takin' th' wizz, Roger. :wink:
The cam mounted pulley arrangement was/is introducing another opportunity for the thing to leak. As if there weren't enuff already. :devilgrin:
I did miss-speak with 'exhaust' as opposed to intake. my bad. :shocked:
Roger
Bronze
A little bit of oil leaking from the engine, gearbox, final drive, etc., stops some of the chassis rusting away.
M MGA RHD twin cam steering pinion MG 0
B Anyone have a Europa Twin Cam for sale? Lotus 6
B Twin OH Cam for the BIG Healeys Austin Healey 15
M MGA MGA Deluxe / Twin Cam brakes MG 2
David Townsend MGA Rocket Ralphie's Twin Cam MG 4
glemon MGA Twin Cam MG 4
David Townsend MGA MGA Twin Cam Illustration MG 0
T Twin Cam Healey Austin Healey 20
Brinkerhoff MGA MGA Twin Cam handbrake parts MG 3
P MGA Where is my Twin-Cam? MG 15
P MGA MGA Twin Cam owners manual. MG 1
aeronca65t MGA MGA Deluxe/Twin Cam? MG 9
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
Marvin Gruber MGA MGA Twin Cam MG 11
PAUL161 MGA STOLEN MGA TWIN CAM!!! MG 0
glemon MGA MGA Twin Cam MG 5
S MGA 1959 MGA Twin Cam on eBay...?? MG 17
glemon Is this a Twin Cam MG 8
B MGA Pic .of my old MGA twin cam MG 10
GeeBee1 Twin Cam - not much time left MG 34
aeronca65t "Real" Escort Twin Cam Other British Cars 18
C Europa Twin Cam Autocross Car Lotus 3
poolboy Twin Cam MG 3
S 59 MG A Twin-cam MG 8
RobT Twin Cam Timing Chain Adjustment Lotus 14
curtis Twin Cam engine question Lotus 41
aeronca65t Escort Twin-Cam Racing 7
curtis Escort Twin Cam Rev Counter Other British Cars 13
curtis Escort Twin Cam Lotus 25
beaulieu MGA MGA twin cam head on non twin cam motor ? MG 9
jackq Twin Cam MG 5
Simon TR4a MGB MGB Twin cam? MG 3
Sherlock MGA Help locate an MGA Twin Cam MG 1
D HRG twin cam Other British Cars 13
K Marcos GT Weber Emulsion tubes on ethanol/E85 Kent X flow twin 40 DCOE 32 Other Cars 2
S For Sale twin Weber 40 DCOE 31 set Other British Classifieds 0
G Twin HS4 Su's leaking fuel Spridgets 18
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
T For Sale Group 44 Replica TR7 V8 Twin Turbo Project - $25,000 Triumph Classifieds 0
D Experience with Mallory twin point distributor. Austin Healey 5
johnrip Wedge TR7 fuel in carbon canister-twin carb model Triumph 10
Foura TR4/4A TR4A Exhaust - Twin or single? Triumph 8
vette Twin Reservoirs Austin Healey 2
S TR6 twin dgvs on a tr6 Triumph 26
theleisure twin-engined-4x4-1966-twini-cooper-s British Motor Corp 1
T Twin barn finds-one is a Jag. Jaguar 3
S Ford Crossflow on twin 40s. Help needed! Other British Cars 3
G Wedge TR7 with twin webers Triumph 1
