Ford Crossflow on twin 40s. Help needed!
SkodaMart
Hi, I have recently purchased a Westfield SEi with a Ford crossflow (Kent) engine. It supposedly has a Piper 285 cam shaft, although upto now I have seen no evidence of this, it drives and idles like it has a standard road cam.
It is fitted with twin Weber 40 DCOEs.
When I bought it, it was running extremely rich, this was cured by changing the choke size from 30mm to 32mm. The original (rich) settings are as follows: Choke 30mm, Main jet 115, Air 180, Emulsion tubes F11, Idle jet 45 F8.
I have changed to: Choke 32mm, Main jet 125, Air 180, Emulsion tubes F16, Idle jet 45 F9.
The car drives much better and is far more willing to rev than it was, however it still seems to be running lean at 4000-4500 rpm. I feel a surge of power at 5500 rpm so I suspect that the airs are correct and the mains may need to go to 130s. Can anyone offer any help or advice as I am new to this twin, twin choke carb game.
I suspect I am getting around 110 Bhp. The car should be able to produce around 125Bhp.
gjz30075
I think you're on the right track with upping the mains to 130. I would also drop the air to 170. If you can get on a rolling road, or otherwise known as a chassis dyno, with an AFR meter, this will tell you for sure where you're at.
Problem is, with twin DCOEs, is the expense of experimentation. Any jet change is $$, times four, and the same goes for any other brass item change in the carb.
Good luck.
S
SkodaMart
Thanks for your help, I have used this site:
https://www.geocities.com/motorcity/9526/carbs.html?200929
Using there formula I think I have got it right. Plugs look ok at all rpms and it is running pretty good.
Two things I would do first next time is adjust valve clearances (tappets) and balance the carbs ( I used a piece of tubing to listen to the hiss, which works far better than you would imagine!)
I have settled on 32mm chokes, 45 F8 idles, F16 emulsion tubes, 130 mains and 180 airs.
My engine (to the best of my knowledge) is a Ford Kent (Crossflow) 1700cc with twin DCOEs, Piper 285 cam and ported head.
I hope this helps someone else in future.
I would be interested in anyone elses jet selection for a similar setup.
Mart.
C Ford pre-crossflow valve train Other British Cars 2
C Ford 1500 Kent pre-crossflow mystery Other British Cars 16
Bruce Bowker Ford 1700 Crossflow Other British Cars 4
AngliaGT Saw These Today (This is FORD Country?) Spotted 2
AngliaGT '64 Ford F100 Spotted 2
AngliaGT 1969 Ford Galaxie Spotted 3
algot1901 1950 Ford Prefect Brake Lining Other British Cars 1
algot1901 Window Channel Ford Prefect Other British Cars 5
algot1901 How about an English Ford Folder FORUM Navigation Questions 1
algot1901 1950 Ford Prefect Paint Other British Cars 5
algot1901 Rear Seat Bottom/Frame for 1950 Ford Prefect Other British Cars 12
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
JPSmit Ford Taunus - never seen on in the flash before Spotted 4
Sherlock 1982 Ford F150 stepside vs 1975 Triumph TR7 Other Cars 4
AngliaGT New Supra,BaT Ford Bronco Spotted 0
C Wanted Ford Kent Pre-Cross Flow Gasket Other British Classifieds 4
TRMark Ford Anglia/Prefect USA parts supplier Other British Cars 7
Lin Ford Versus Ferrari Question Austin Healey 23
AngliaGT My Old Ford Consul Capri Other Cars 0
Basil Ford Tractor Spotted 12
O Ford Cars Other British Cars 18
C Wanted Wanted - Ford Cortina "bullet" style gearbox Other British Classifieds 1
H Ford T9 5 speed question Restoration & Tools 1
3798j Ex-Bell Telephone "55 Ford F100 Other Cars 8
C For Sale AC Bristol with a Ford engine Other British Classifieds 0
M TR2/3/3A Ford Alternator Conversion Problems Triumph 10
Paul_1 Vintage Ford Cortina Spotted 12
Steve Ford Capri Spotted 13
PAUL161 6.0 Power Stroke Ford Truck Other Cars 4
D Mazda 3 vs Ford Focus Other Cars 5
aeronca65t Glider in store-Ford GT, etc Spotted 1
P Wedge Ford powered TR7 Triumph 5
Sherlock Ford Sierra RS Cosworth Spotted 1
jackq 47 Ford 2 dr Deluxe Other Cars 4
DrEntropy 1963 Ford Fairlane Spotted 1
G Ford F250 Other Cars 13
mailbox Ford power steering pump Other Cars 0
C Ford 1500 Kent Pre-Cross Flow Mystery Lotus 20
bcliff Ford Model Y English for sale Other British Cars 1
aeronca65t Ford GT Spotted 7
JPSmit Lotus Formula Ford Racecar Other British Cars 2
jackq 46 Ford...finally Other Cars 11
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
A Ford GT Spotted 2
kylekoehler 1953 Ford Consul burned piston Other British Cars 9
J Another pic of '67 Ford GT MKIII Other British Cars 13
J Ford GT MKIII Other British Cars 0
glemon 800,000 ford truck Other Cars 9
CZ_Dave Help in Identifying this British Ford? Other Cars 11
bcliff For the English Ford Lovers Other British Cars 11
