Trafalgar Washer Bottle lid decals
Tech396
Longbridge Trafalgar Washer Bottle lid decals
Trafalgar bottle decal 001_crop.jpgI have a small number of Trafalgar John Sydney glass washer bottle lid decals for sale.
The factory washer bottles in 1957 and early 1958 Austin Healey 100/6s used a lid with this logo printed on them.
Those lids are impossible to find, so here is a good alternative to the printed lid.If you are looking for those extra details.
I have two sizes. 55mm and 57mm, both with a 6 mm center hole.The 57s go to the outer edge and the 55s are just shy of the outer edge.Your choice.
NOTE. These will only work on the smooth top lids.
The cost including shipping to the USA and Canada is $20USD ea and only $2 more to the rest of the world.
Paypal accepted I can be reached directly at piharry@shaw.ca
5 Trafalgar logo on BN4 washer bottle Austin Healey 0
C The ongoing saga of the "Trafalgar Bottle Cap" Austin Healey 4
C Size or matching screw on cap for Trafalgar bottle? Austin Healey 0
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A Picture of the Zinc washer. Triumph 3
W Glass Washer Bottle Lids Austin Healey 0
T Tudor Washer Bottle Holder Austin Healey 1
J Thackery Washer Austin Healey 3
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
W Tudor windscreen washer bottles Spridgets 0
J TR4/4A Washer bottle bracket screws Triumph 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
M TR6 Wiper washer knob Triumph 5
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
B TR4/4A Thrust washer issue Triumph 11
4tecdog Fibreglass bonnet washer fittings Spridgets 5
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
R Windshield Washer Pump Repair Austin Healey 9
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
B TR6 Winshield washer bottle location Triumph 2
D Wanted washer for hood catch Triumph Classifieds 2
K Windscreen Washer Question Austin Healey 26
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
NutmegCT T-Series Carb banjo washer leaks? MG 9
G TR4/4A Windshield Washer Tubing Routing Triumph 1
B Windscreen washer pump upgrade Austin Healey 10
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
D TR4/4A square engine mount washer necessary? Triumph 6
Got_All_4 TR2/3/3A Push switch for washer fluid pump Triumph 4
K Thrust washer Austin Healey 4
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
K Starter Drive Washer? Austin Healey 1
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
bighealeysource Fibre washer on O/D drain plug doesn't fit well Austin Healey 7
theleisure TUDOR Washer Bottle Look-a-Like Oil Catch Can Spridgets 3
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
Rut MGB Oil pressure gauge leather washer MG 13
K TR2/3/3A Rear spring again....front pin "D" washer? Triumph 7
Jim_Stevens TR2/3/3A A-type OD operating valve copper washer Triumph 3
M TR2/3/3A TR3A gas cap fiber washer Triumph 6
I TR6 Windshield washer jets...placement and installation Triumph 1
B Tudor washer bottle Austin Healey 9
Jim_Gruber Repairing BE Washer Pump Spridgets 5
PatGalvin TR2/3/3A Oil Pressure Gauge Leak - Leather Washer? Triumph 12
