TR2/3/3A Rear spring again....front pin "D" washer?
karls59tr
Bronze
the metal bushing that holds the front Pin has has a protruding serrated edge that holds the D washer out about 1/4" when torqued to 30ft/lbs. On the old spring on the other side that I haven't removed yet the D washer appears to be "flush" with the spring bushing loop. Is this gap an issue? Does the D washer need to be flush with spring?
M_Pied_Lourd
I just replaced my silent block bushings in the front eye of the rear leaf springs that the pin goes through. The edges of the new silent block bushings protrude very slightly outside the edge of the spring eye. My D washer does snug up against the bushing but doesn't touch the metal of the spring.
Cheers
Tush
CJD
This is the best pic I could find. Definitely not touching, as that would induce a rattle or knock on corners. Mine may not be 1/4", but it is very close to it.
TR3driver
Great Pumpkin - R.I.P
Should be OK, I believe. I think the washer is a failsafe in case the rubber fails.
However, I found another problem with those serrated sleeves when I took the spring back off. They are smaller outside diameter than the originals were, so mine at least was working it's way in between the frame tube and the pin. The D washer was loose, even though the cotter pin was still in place. No real damage done with only a few thousand miles, but might have been a problem in the long term. You might want to check the nuts for tightness after a few thousand miles.
If I do ever put those springs back on the car (not bloody likely), I'll replace the bushings with ones that have the correct size sleeve in the middle.
K
karls59tr
Bronze
"checking for tightness"...would it be a bad idea to use a Nylock nut in this location? Also is it possible to get the proper torque on a Nyloc nut?
CJD
When I read Randall's story, it sounds like it is not a matter of the nut loosening...but rather the steel sleeve of the bushing eating into the frame tube over time. So, either nut would work, so long as you check it and re tighten occasionally.
TR3driver
The factory liked Nylocs better than I do. If they chose not to use one, I suspect they had good reason(s). For one thing, I'm not certain there are enough threads exposed to fully engage with the nylon insert. Nylocs sometimes back off from vibration and heat, while cotter pins are forever. Besides which, you're supposed to replace Nylocs every time they are disturbed ... do you really want to do that?
PS, on the subject of replacing Nylocs, a woman I know had the rear wheel fall off her Mazda 323. Apparently the previous mechanic didn't know to replace the Nyloc, and it worked loose. Of course she didn't notice until the wheel was laying on the pavement, which pretty well ruined the spindle. A replacement spindle cost more than she paid for the whole car! (Ok, she got the car for free, but still.)
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
jfarris TR2/3/3A Relacing rear spring busings Triumph 3
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
GeorgeC Rear spring disassembly - BN1 Austin Healey 1
J Rear Oil Seal Kit - Spring Austin Healey 9
D Rear spring length question. Austin Healey 6
55modified Replacing rear spring eye bushings on a BN1. How difficult? Austin Healey 8
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
4tecdog Rear Spring installation Austin Healey 10
Popeye TR4/4A Rear brakes - spring plates and drum alignment Triumph 3
Popeye TR4/4A Rear leaf spring - do I have a TR4 spring on my 4A?? Triumph 4
M Rear spring plate bolt Spridgets 1
P Spitfire Mk3 rear spring Triumph 4
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
Jim_Gruber BE Rear Brake Spring Orientation Spridgets 13
Popeye TR4/4A TR4A solid axle rear leaf spring question Triumph 14
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
GTP1960 TR2/3/3A Brass /delrin bushings on rear spring shackle? Triumph 3
K TR2/3/3A Bronze and delrin rear spring bushes. Triumph 0
K TR2/3/3A Revington's Rear Spring Locators? Triumph 1
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
Rob Glasgow Rear Spring Shackle Austin Healey 1
K TR2/3/3A Revington's Rear Spring Location Kit? Triumph 9
K MG Midget rear drivers side spring sag? Spridgets 7
K General Tech MG Midget rear spring sag? MG 2
L WTB - rear leaf spring, late model Sprite / Midget Spridgets 8
D TR6 Rear Spring Triumph 5
J BJ8 early P2 rear spring mystery - what do I have. Austin Healey 6
B Spitfire Torque specs on rear spring bolt, Spitfire Mk3 Triumph 2
T TR2/3/3A Rear spring front pin removal Triumph 28
J Rear spring front pin stuck Austin Healey 8
H rear leaf spring to chassis bushing Austin Healey 11
6 rear semi eliptic spring plate - old school mechanic Spridgets 1
DornTRoriginal TR2/3/3A Rear Axle & Leaf Spring Installation Questions Triumph 3
DornTRoriginal TR2/3/3A Rear Suspension Front Spring Attachment Pin Problem Triumph 5
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
J Rear Spring question ?? Triumph 6
spitfun Wanted:Triumph Spitfire race rear spring Racing 2
R Rear Leaf Spring Removal Triumph 10
R TR2/3/3A TR-3A Rear Leaf Spring Broken Triumph 3
Rut Rear Spring Restoration Spridgets 41
M Since rear spring conversion was mentioned Spridgets 34
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
vette Rear Spring Shackle bolts Austin Healey 3
rjc157 rear spring height Austin Healey 10
smaceng BE rear shoe steady spring Spridgets 1
RAC68 Rear Spring Lift Austin Healey 9
