TR6 Winshield washer bottle location
BS Palmer
Bought a 1973 TR6 recently and there was no winshield washer bottle so I bought a square shaped one but wonder wheres the best place to install it. I bought the seperate windshiled washer motor and found the only wiring so am good there. Any photos of how you might have one installed woudl be appreciatted. Thanks. bspalmer
ed_h
This is for a left hand drive car:
walshja winshield washer nozzle is loose Spridgets 20
Woodie winshield washer jets Spridgets 1
A Winshield, Stanchion to frame assembly. Triumph 4
G B.E winshield installation question Spridgets 5
O TR2/3/3A TR3 Winshield Sealing Triumph 9
I Bugeye winshield wiper questions Spridgets 7
R TR6 Tr6 Winshield Frame Restoration Triumph 7
sonuvagunsmith Winshield mounting bolt MG 10
Mark_Gibson TR-2 Winshield Removal from Frame - Success! Triumph 8
D TR6 Tr6 Winshield interference Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A Picture of the Zinc washer. Triumph 3
W Glass Washer Bottle Lids Austin Healey 0
T Tudor Washer Bottle Holder Austin Healey 1
J Thackery Washer Austin Healey 3
V MGB Thackery (double coil spring) Washer Substitute? What else works? MG 9
W Tudor windscreen washer bottles Spridgets 0
J TR4/4A Washer bottle bracket screws Triumph 3
C Removing AH Sprite Mk 1 windscreen washer pump Restoration & Tools 2
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
M TR6 Wiper washer knob Triumph 5
steveg TR6 Late Wiper/Washer Switch - What Happened? Triumph 3
B TR4/4A Thrust washer issue Triumph 11
4tecdog Fibreglass bonnet washer fittings Spridgets 5
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
R Windshield Washer Pump Repair Austin Healey 9
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
M TR2/3/3A Standard Engine Trust Washer Thickness Triumph 18
D Wanted washer for hood catch Triumph Classifieds 2
K Windscreen Washer Question Austin Healey 26
Tim Tucker TR6 Trailing Arm NYLATRON bushing-washer gap questions Triumph 4
NutmegCT T-Series Carb banjo washer leaks? MG 9
G TR4/4A Windshield Washer Tubing Routing Triumph 1
B Windscreen washer pump upgrade Austin Healey 10
Csarneson Source for Distributor Fiber Thrust Washer Austin Healey 3
D TR4/4A square engine mount washer necessary? Triumph 6
Got_All_4 TR2/3/3A Push switch for washer fluid pump Triumph 4
K Thrust washer Austin Healey 4
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
K Starter Drive Washer? Austin Healey 1
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
B Two Longbridge BN4 Questions - Indicator Light and Washer System Austin Healey 8
bighealeysource Fibre washer on O/D drain plug doesn't fit well Austin Healey 7
theleisure TUDOR Washer Bottle Look-a-Like Oil Catch Can Spridgets 3
longbridgehealey Longbridge built 100-6 dual washer nozzle Austin Healey 6
Rut MGB Oil pressure gauge leather washer MG 13
K TR2/3/3A Rear spring again....front pin "D" washer? Triumph 7
